Delco Distributer Buy or Rebuild
zerozeroniner Avatar
North Carolina, USA   USA
I want to refresh/rebuild the Delco that came with my 72 GT6. That one has about 125k miles.
I have the same model from a very low milage parts car, less than 17K miles.
A new reproduction Delco form Spit Bits is $200.
A rebuild is $200 plus parts.
I'm not looking to go electronic, and I'd like to stay with what came on the car (vs. a beer performing Lucas)
Any thought on a path forward?
What problems are you having with the units you have? Why are you looking at rebuilts or aftermarket?
The low milage distributor seems ideal.
If you have shaft wobble, new bushings are not difficult to replace. Just switching in an ignition kit like petronix will deal with most other problems.
twomanytriumphs Avatar
Kelso, Washington, USA   USA
1965 Triumph TR4 "My Baby"
1977 MG MGB
Oil the spare unit, refresh the points and condenser and go for it. I've swapped to Lucas more for parts commonality than anything. Kyle.
Las Vegas, Nevada, USA   USA
How do you feel about doing the rebuild yourself?
And a writeup? grinning smiley
I don't know about doing it myself. Certainly I can do the bits and pieces, points, condenser, cap, etc. I can clean and oil, even replace the springs, if needed.
I have no clue about the weights and checking the "curve".
I think cleaning it up, checking for wobble and flat and then seeing how it runs is the best strategy for now.
This is my first rodeo, sometimes I just assume that to do it right means someone else, with experience does it, but thats no fun :-)
In reply to # 1498280 by zerozeroniner I don't know about doing it myself. Certainly I can do the bits and pieces, points, condenser, cap, etc. I can clean and oil, even replace the springs, if needed.
That's the spirit!
Hang out with enough people too broke to afford someone else to do it and you'll be surprised what you'll learn.
dplass Avatar
dplass Silver Member David P
Merrick, New York, USA   USA
2011 Ford Fusion
Too bad you're so far away -- I'm in the midst of rebuilding my (GT6) distributor and we could have compared notes...
-D
1972 GT6 MK3 "The Beast"
