install radio brace
vnunnally Van Nunnally
Richmond, VA, USA   USA
have 1972 triumph spitfire , replacing with new carpet and put carpet over trans tunnel , it seems when i try to put radio bracket over its a very hard fit , and when i push it hard the leather pouch over my shifter looks like it is beginning to rip . and there is what looks like a piece of hard plastic maybe its called a trim at the bottom of entire dash and i am starting to hit that . should i remove that as i dont want to break that to and if i do remove it how do i do that ?? thanks Van
SpiTazz72 Avatar
SpiTazz72 Bryan H
Magnolia, TX, USA   USA
I've said that piece was probably the first part on the assembly line. I fit the top of the brace in place first then pushed the lower legs into position. Look up under the dash to see where it fits first because there's an edge it need to go behind.
carChips Avatar
carChips Victor Harnish
Kelowna, BC, Canada   CAN
1933 MG Magnette
Do you have a plastic trans cover? The lip may have to be trimmed.
'S all for now
Vic
It seems that one of the tricks is getting it in from the right direction. I think that was fitting the top in the trans cover so it is behind the dash then rotating the top forward and upward as you also press the feet down and back. Sort of rotating the whole thing. It will be a tight fit but that is how it goes.
have original one
cbez Cole B
Fallbrook, CA, USA   USA
Yeah this part sucked. When I twisted it into place the vinyl cover on the 'feet' started to come off. Luckily they're mostly covered
1971 Triumph Spitfire MK 4
SpiTazz72 Avatar
SpiTazz72 Bryan H
Is the new carpet cut for the feet or bolt holes?
DerbyRam54 Neville Wardle
Branford, CT, USA   USA
If it's anything like a late 1979 you will almost certainly need to cut the plastic gearbox cover because it is considerably wider than the original one.
You also need to cut the carpet and make sure it is nowhere near the set screws that retain the support. You don't want pieces of the carpet getting caught in the fine threads of the screws.
I removed carpet and gearbox cover, fitted the support in place and marked on the floor exactly where the "feet" of the support came and then used that as a guide to cut the cover and the carpet. I can't say it was the neatest job I ever did but it did the job of getting the support reinstalled, which tightens up the dash considerably, so well worth doing.
Unless you like the idea of a Spitfire being 1,858 parts all travelling in convoy.
N5329K Avatar
Pacific Grove, CA, USA   USA
On my 78 (with the ABS gearbox cover) the H bracket radio brace went in just fine without any cutting. It wasn't fun getting the braces bolted in under the dash, but the trick (on my car) was to tilt the H bracket forward, place the top where it needed to be, then push the bottom into place and over the holes. The holes can be hard to find...I stuffed bright orange foam ear plugs into the holes before setting the H bracket. That made the holes a little easier to rediscover.
My carpet is not very thick. I wonder if your carpet is plusher, making the bracket harder to slide into place?
Robin
its not cut 4 anything yet
Falkon Avatar
Falkon Al Martin
Appleton, WI, USA   USA
I recall pushing the base to the front of the car a little bit, then prying out the top towards me. The original cover "bent" in enough for this to work. Top goes behind, "under" the trim piece.
Edited 1 time(s). Last edit at 2017-11-13 05:45 PM by Falkon.
You guys are making this hard. Get a bottle jack and stick a short 2x4 under the dash and jack it up slightly.
Don't go overboard, but the front of the dash moves very easily.
Make sure the brackets holding the steering column are loose, the one on the left is the one that needs to be undone as the one on the lright goes into the top bolt of the support frame. .
Fictioneer Avatar
Fictioneer Doug Hirt
Mines been out of the car a few years now, and now when I tried to fit it, it too seemed a tad too long also. I guess there is some settling that occurs in that area. Not much, maybe a 1/4 inch. Reckon I'll be reinstalling the fixture.
Doug
Yes mine seems too long now interesting
Falkon Avatar
Falkon Al Martin
This might sound silly, but how did you remove it. Reverse the process.
crowbar-hi.jpg    14.2 KB
1959 Triumph TR3A
