Stromberg Carb Sync tool
regnaston Dale Sanger
In reply to # 1497723 by skyking1231 +1 ......
easy to use...like mentioned...make sure you have the right sight gasket thingy. I ordered a different set fot hte HS4's. the ones that it came with would fit....but the other onese i ordered (i forgot the size), fit much better.
In reply to # 1497715 by Pats54 This is what I have it works well
They sell a variety of the black rubber base's to fit the carb you need
$40 or so
So which one is the right size for this ?? Will the 4025 work without buying additional parts?
In reply to # 1497859 by Tonyfixit Am I the only one that uses this method?
Has anyone even tried it?
Tony,
I do that on SUs. I feel lucky not to have to do it on ZS carbs. Too many other widgets on ZSs to suit me.
