Stromberg Carb Sync tool
regnaston Dale Sanger
What do you guys use to sync your Stromberg Carbs?
Will something like this work?
https://dunebuggywarehouse.com/deluxe-darburetor-synchronizer-for-multi-carb-engines.html
or is there a cheaper option?
Yes, a stethoscope (a 'playing Doctor' toy will do) or 3 ft of hose.
Put one end to your ear and compare the sound of the hiss at the carb intakes.
Adjust the idle screws until they sound even.
Las Vegas, Nevada, USA   USA
There's the bottle option.
Popular on motorcycles and snowmobiles.
In reply to # 1497632 by Doug in Vegas There's the bottle option.
on the link I posted the instrument goes into the main hole of the carb.. where would I put the vinyl tube?
carChips Avatar
carChips Victor Harnish
Kelowna, BC, Canada   CAN
1933 MG Magnette
Dale, the one you posted the link to is pretty much what is recommended by Burlen Fuel. I use the Gunson carb sync, they're like 12 bucks. Or they were.
'S all for now
Vic
In reply to # 1497641 by carChips Dale, the one you posted the link to is pretty much what is recommended by Burlen Fuel. I use the Gunson carb sync, they're like 12 bucks. Or they were.
this?
https://www.ebay.com/itm/GUNSON-CARB-BALANCER-Easy-read-scale-indicates-the-air-flow-/160701111171
In reply to # 1497639 by regnaston
In reply to # 1497632 by Doug in Vegas on the link I posted the instrument goes into the main hole of the carb.. where would I put the vinyl tube?
The lower tap on a ZS.
carChips Avatar
1933 MG Magnette
In reply to # 1497647 by regnaston
this?
Yup, looks like it went up since I bought mine.
'S all for now
Vic
So with this tool .. is there a different model for our cars?
https://www.ebay.com/itm/Dual-Carb-Sync-Uni-Syn-Carburetor-Synchronizer-Weber-Austin-MG-Jag-Edelbrock-/322547554165
Some of the links do not list Spitfires or GT6 as compatible.. I would think that since it is just testing vacuum from the carb as long as it fit over the hole it would be fine
Pats54 Avatar
Pats54 Gold Member Mark M
Maynard, Mass, USA   USA
1979 Triumph Spitfire 1500
This is what I have it works well
They sell a variety of the black rubber base's to fit the carb you need
$40 or so
IMG_2210.jpg    30.9 KB
1964Spitfire Avatar
1964Spitfire Tim P
Santa Clara, CA, USA   USA
In reply to # 1497701 by regnaston So with this tool .. is there a different model for our cars?
I've been using the Uni-syn for many years on Strombergs and SU's. They work fine. Here's a review from an MG guy = http://mgaguru.com/mgtech/carbs/cb135.htm
skyking1231 Avatar
Mt. Sinai, NY, USA   USA
+1 ......
easy to use...like mentioned...make sure you have the right sight gasket thingy. I ordered a different set fot hte HS4's. the ones that it came with would fit....but the other onese i ordered (i forgot the size), fit much better.
In reply to # 1497715 by Pats54 This is what I have it works well
$40 or so
colodad Avatar
country school
carb diagram 2, Bob M.jpg    32.3 KB
Am I the only one that uses this method?
Has anyone even tried it?
