GT6+ vent windows on a Spitfire MKIV?
Fictioneer Avatar
Fictioneer Doug Hirt
Will these fit?
Doug
Herald948 Avatar
Herald948 Andrew Mace
KindaMaybeYeahSorta... but you'll need real GT6 door glass as well.
Have a look at the Spit6's on the forum, lots did this as I will.
Look in the Registry top 10, a few there.
Fictioneer Avatar
I know it has been done. I guess my question is more about the different heights in windscreens. Aren't the squaretail windscreen taller? Are all GT6 vent windows the same height? Also, is there an issue with rounded corners?
Doug, the round tails have a rounded window at the rear and require the GT6 window to be cut. The square tails will fit a treat with no problem with the top, as the later top is made to fit a square window.
The vents are the same on both. The early cars had a brace welded across the middle of the vent framing.
Jim did his (Scardini1) but I had already got mine cleaned up and in place when he got here. They di help on his 2600 mile trip in the middle of the summer.
twomanytriumphs Avatar
Kelso, Washington, USA   USA
1965 Triumph TR4 "My Baby"
1977 MG MGB
Straight forward swap Doug. The difference in height between the screens comes from the mkiv having an integral windscreen surround, while the mk3 has a removable frame. I think I've got spare door glass around. Kyle.
Gt6s Avatar
Gt6s Laurence Cochrane
Newtownards, UK   GBR
1972 Triumph GT6 MkIII "2600 EFI"
1973 Triumph GT6 MkIII "2500"
1976 Triumph Spitfire "Sixfire 2500"
In reply to # 1497252 by trrdster Doug, the round tails have a rounded window at the rear and require the GT6 window to be cut.
You cannot cut a Gt6 door glass. These are toughened glass and will shatter into a million pieces on any attempt to do so.
Laurence
Laurence, Not something I would attempt, but have seen it done a couple of times.
Would scare me for sure, might try it if I had a stack of old ones.
https://www.bing.com/videos/search?q=cutting+automoble+window+glass&view=detail&mid=15CD7FD687E7EC8E5B6B15CD7FD687E7EC8E5B6B&FORM=VIRE
Of course GT6 glass may be a different animal, sure does make a mess when broken inside a door.
If putting a vent in a early door, rather than cut the rear of a GT6 window on the curve, why not cut the straight line on the already Spitfire door, surely easier.
Wayne,
That is cutting laminated glass like a windshield. NOT tempered glass like the side windows in a Spitfire or GT6.
Thanks Paul, scratch that!
Gt6s Avatar
Newtownards, UK   GBR
In reply to # 1497307 by trrdster Laurence, Not something I would attempt, but have seen it done a couple of times.
Round cut Gt6 door glasses you may have seen, specially made NOT CUT.
A few folk have had them made over the years.
Laurence
Herald948 Avatar
Also, unlike the Spitfire, GT6 door glass is actually "sided" in that it has a very slight upwards curvature.
Waterjet can cut any glass.
Just sayin'
