cbez Cole B
Fallbrook, CA, USA   USA
Hi guys,
1) electric choke
2) red from dizzy
1971 Triumph Spitfire MK 4
20171109_203957.jpg    53 KB
Brad.Cogan Avatar
Brad.Cogan Bradley Cogan
Brad Cogan
Brad.Cogan Avatar
Brad Cogan
TinDrum Herald Ma
cologne, NRW, Germany   DEU
sorry, wrong picture
Herald
colodad Avatar
Grand Junction, CO, USA   USA
colodad Avatar
colodad Avatar
Here's my current setup.
Maybe it can help.
cbez Cole B
cbez Cole B
1972 Triumph GT6 MkIII
