Wheel hub & Felt Seals
Herald948 Avatar
Herald948 Andrew Mace
In reply to # 1497010 by spitfire50 Cole,
Bruce gives a close approximation of the procedure I have seen (but never followed) in at least one manual.
From your pic I would say you do have one of the too thick seals.
I've been reusing the old seals for most of the thirty + years I have owned my Spitfire, so I can't offer much guidance on trimming the thick ones.
For whatever it's worth:
1. My experience is like Paul's; I tend to reuse without drama.
2. Several years ago, I scored a good deal on NOS (maybe NORS?) seals. Not surprisingly, the height of the dry felt was far closer to the used ones, far thinner than what is pictured above!
RiPe Richard Peetz
Sequim, WA, USA   USA
Hey All,
I wrote an article for Spitfire & GT6 magazine about this a few years ago. Mainly showing measurements indicating ALL the replacement metal felt holders from ALL sources I tried, from both here and abroad, were too large in diameter to press fit into the hubs without deforming the felt holder. First choice is to use the stock felt holders and just replace the felt, cutting it down if necessary. Next choice, in desperation, if you absolutely have to (I had to do one), is reducing the diameter if the new felt holders, which I demonstrated in the article. The available new metal bases are quite fragile, being MUCH thinner metal than oem and the side walls are twice as tall. At the time of the article, I spent a lot of time trying to find a modern rubber/spring seal that fit, and while i.d. and o.d. matches were available, standard application sizes were either too short or too tall for our application. Maybe there are some more choices out there now. The oem does the job, though.
Interestingly, my Autobook and Clymer manuals and my old edition of Haynes says to soak the felt in oil. My newer edition of Haynes says to grease them. I used oil, anybody tried grease?
Regards,
Richard
IanF Ian Furqueron
Croydon, PA, USA   USA
It's been awhile... but I installed GT6 front brakes on my old Spit 6 (regretfully sold in 2009). I soaked them in oil as per instructions I received.
Personally, I wouldn't worry too much about the felt thickness. They'll wear down against the spindle to whatever thickness they need to be.
I'll probably order a set of these from someone soon as I probably need to service the front bearings on my GT6 and I have another set of GT6 front brakes to install on my Spitfire, so I'll probably be going through this exercise again.
bonnett1954 Avatar
Hi Tony. You got a source for those?
In reply to # 1497149 by Tonyfixit
However, I now understand from links that members posted that 'proper' neoprene seals are available.
In reply to # 1497426 by bonnett1954 Hi Tony. You got a source for those?
Sorry, no. I had already cut leather seals, as I wanted to get the car back on the road ASAP. I did not have further problems so have yet to investigate those links.
Dave,
Try some looking around on Lotus sites. The 1960s Elan and Europa both used the Triumph vertical link and hub. ISTR they have found a rubber seal that works.
bonnett1954 Avatar
No problem Tony. Thanks for the tip Paul.
Azoth Shane G
Los Angeles, CA, USA   USA
From reading on some lotus sites, you can either try and get them from http://davebean.com, or this website: https://www.limora.com/en/oil-seal-1-141031.html. They seem pretty expensive though. If the size was known it could probably be bought somewhere else for much less.
If someone could post the outer diameter (I know the inner diameter form a used bearing, and I assume the thickness to be less than 1/4"winking smiley I could look something up.
Greg1835 Avatar
Greg1835 Greg S
Rudolph, WI, USA   USA
NATIONAL 223822 might do it. shaft size - 1.496, OD- 2.098 thk.- .315 A thinner one might be better though.
https://www.fmmotorparts.com/fmstorefront/federalmogul/en/USD/Driveline/Wheel-Bearings,-Seals,-Hub-Assemblies/SEALS-WheelSeal/National-Oil-Seal/p/RNT223822
1973 Triumph TR6
