New Softop put on! tips on waterproofing?
cwm3232 Colin M
Boston, MA, USA   USA
Hey guys! 1980 Spit and I just got a new softop put on, they did a pretty good job but they were adamant the whole time that it'd never be water tight. I get a bit of water coming in through the top of the windows which makes sense but I wanted to know if anybody had any good ideas to make that a bit better? I think I can add a bit of weather stripping to the existing roof and as long as it folds down well I think I can help my situation. In addition I was driving in the rain the other day and my ankle kept getting drips on it- slightly concerning considering it was controlling the accelerator well under the dash and away from the windows. Just wondering if anybody had any thoughts! Thanks guys!
carChips Avatar
carChips Victor Harnish
Kelowna, BC, Canada   CAN
1933 MG Magnette
There are several rubber grommets on the firewall that seal the wire loom and cables, one of those could be damaged or missing and water is spraying in to the cockpit.
You can try adjusting the windows to fit inside the new top when the windows are up.
'S all for now
Vic
Las Vegas, Nevada, USA   USA
Go to the typical big box hardware and pick up some neoprene weather strip and some foam pipe insulation that's like those pool noodles. You can get creative with various sizes and they cut with scissors.
Eastbourne, East Sussex, UK   GBR
Hi Colin,
The drip on your ankle will probably be from rain leaking past the windscreen washer jets on the scuttle or, less commonly, getting in round the wiper spindles. Here in the UK we have stuff called 'Seek and Seal' which works well but only use a tiny amount.
Good luck.
Adrian
Edited as I got Colin's name wrong; very sorry Colin
Edited 1 time(s). Last edit at 2017-11-12 04:56 AM by Adrian Cooper.
Falkon Avatar
Falkon Al Martin
Appleton, Wisconsin, USA   USA
Water will splash up onto the firewall, lay on the flat area, and as said, drip in where it's not sealed. Brake & clutch seal rubber.
In reply to # 1497412 by Falkon Water will splash up onto the firewall, lay on the flat area, and as said, drip in where it's not sealed. Brake & clutch seal rubber.
Actually, splashing up from below is a very minor issue.
MOST of the water on the rear deck is due to the fact that the air intake drains onto the rear deck.
You have to admire the effort it took to make sure all of the water would come out in close proximity to the coil.
The little rubber flap provided is to prevent engine fumes from entering the cabin.
Works,.....as expected.
