True Spark Distributor Question
70tbolt Geoff Ullmann
Morgan Hill, California, USA   USA
It appears my 75 Spitfire has a new True Spark Distributor installed but not hooked up. Unfortunately no instructions or information came with the cars paperwork. I was hoping someone could shed some light on this system and how to wire it up properly. Also are they any good? I could not find any information on the internet.
Thanks!
Geoff
41427E.jpg    16.8 KB
carChips Avatar
carChips Victor Harnish
Kelowna, BC, Canada   CAN
1933 MG Magnette
Disconnect battery, red to plus side of coil and black to negative side, that's it. Make sure you have 12 volt coil and no ballast.
'S all for now
Vic
Geoff,
If you find that you do have a ballast in the coil supply you can hook the red wire to any ignition switch controlled wire (white) instead of the coil positive.
Your car is the right age to possibly have a white wire abandoned near the distributor waiting to be used.
Thanks! It's a new coil and I do not see any ballast hooked up.
Regards,
Geoff
Thanks!
Geoff
A Pink and White wire will be a resistance wire, if you see one connected to the coil + terminal. beware.
colodad Avatar
In reply to # 1496661 by 70tbolt Thanks! It's a new coil and I do not see any ballast hooked up.
Regards,
Geoff
no pink with white stripe wire to the coil positive along with a white with yellow stripe wire from the starter solenoid ?
you have tested voltage with a meter?
Is it possible the diagram is wrong, and the ballast pink/white is actually connected at the starter solenoid like later diagrams show, not to the coil itself?
Edited 2 time(s). Last edit at 2017-11-08 10:42 AM by colodad.
75 diagram Omalley Federal with wire colour notes.jpg    73.1 KB
Thanks!
No pink white wire in sight anywhere. Has a new starter motor from BritishStarters (which I am still trying to figure out) and it is not connected yet. Have not checked for voltage yet as all things are not hooked up.
Geoff
1969 Triumph Spitfire MkIII
