Stromberg rebuild kits ?
JohnW63 John Williamson
Apple Valley, CA, USA   USA
We will need to rebuild our pair of Strombergs. I checked at Canleys and a lot of the parts on their carb page was shown as " No longer available " . Is this going to be a common problem with these carbs ? Is there a place I can find kits for these ?
Home of the 1968 GT6+ MK II resurrection project
tomster Avatar
tomster Tom Dunbar
Annapolis, Maryland, USA   USA
John,
It looks to me like Moss Motors has rebuild kits for the Strombergs.
DerbyRam54 Neville Wardle
Branford, Connecticut, USA   USA
Check out http://zenithcarb.co.uk/?SID=vgal8gero0o78cro5rrducnd41&___store=zenith
Burlen are the company that now owns the SU and Zenith brands, more is available than you might think when you look at most parts suppliers.
If you do place an order, make sure you add their reference catalogue. It's free, you just pay the additional postage. It's a very useful reference work for these carbs.
Support is perhaps better for the SU carbs, but all is by no means lost for the Strombergs.
No connection other than satisfied customer.
Outfect Avatar
Outfect Dave B
La Sal, Utah, USA   USA
John,
Outside of linkages almost all parts are available for Zenith Stromberg if
you know where to look. Your GT6+ should have ZS150CDSE carbs. Probably
with non-adjustable jets.
Try Joe Curto's British SUperior brand made in NY.
www.joecurto.com
Part #5365. You will also need the bypass valve kits which are sold separate. #BP-014
You can get the factory ZS kits from Burlen LTD in the UK but they are expensive and take 3 weeks to
show up. They are CDSK7 and you also need the bypass kits.
Royze in California makes decent kits. ZE-14 and also need the bypass kits.
DaveInUtah
ContentImage-13814-262323-bp014aa.jpg    23.1 KB
ContentImage-13814-263234-5365.jpg    66.6 KB
Thanks for the resources and info. I was wondering if the GT6 used the 150 model. I asked my Dad to check them out, but haven't heard back.
How do you identify the carbs ? Mine do say Stromberg and CD on the top, but where do you find the rest of the model info ? Yes, I have pictures.
Greg1835 Avatar
Greg1835 Greg S
Rudolph, Wisconsin, USA   USA
There should be a brass tag on one of the 4 screws on the diaphragm cover. It'll have a 4 digit model number.
If there is no brass tag on either of your carburetters the next step could be to remove the air piston and examine the metering needle. At the top of the needle there will be an identifying mark. Assuming a previous owner hasn't played around this should be sufficient to work out exactly what carburetters you have.
That said, there wasn't a lot of variation in the CDSE carburetters fitted to the GT6. The Burlen reference catalogue shows them all using the same gasket pack (GP245) and the same service kit (CDSK7, as Dave from Utah has noted). There are two part numbers for a rebuild kit, CDRK8 and CDRK80. You might need to look at either the brass tag or the needle to determine which of those you need.
But whether you need a rebuild kit at all is perhaps the question to answer. Burlen offers gasket packs (which are what you would imagine), service packs and rebuild kits. The rebuild kit is quite comprehensive and includes new throttle discs and spindles. The service kit is more or less what is in the two photographs Dave posted, apart from the diaphragm which would be a separate part number.
Other suppliers as Dave said can provide what you need, I've quoted from the Burlen catalogue because it's what I have to hand, and their service has been very good. My order arrived within a week though of course that could vary significantly depending on things like customs clearance.
There is a very good document on the Burlen site for the CDSE carburetter at http://zenithcarb.co.uk/zencdsecd2/?___store=zenith
Without knowing what exactly is wrong with the carburetters it's hard to go much further.
The carbs are attached to the intake and have been in a box with other parts for who knows how long and look rather nasty. Better to just rebuild them now, than find out they need it when we try to start the car, a year from now.
We tried to remove the needle from one of the carbs. Even after removing the little set screw entirely, it would not come out. I brushed lacquer thinner on it to see if the old varnished gasoline would let go, but no luck.
The only info we have found is it seems that California sold GT6+ cars all may have come with the same carb. Both of our cars have it. It has a plastic cover that goes diagonally on the side of the carb. Does THIS give enough info to ID what we have ?
They look like this !
Do I then have 175s instead of 150s ?
John,
No,there are 150 CDs with the same cover. Measure the throttle plate opening to determine whether you have 150 or 175 CDs 1 1/2" = 150, 1 3/4" = 175.
I took a carb off and measured. 1.5"
So, with the plastic part and being a 150 CD, does that tell me WHICH CD model it is ?
215spit John R
Phoenix, arizona, USA   USA
That site only lists one kit for every 150 or 175 CD carb on any Triumph. I thought there would be differences ?
