OD in Spitfire
OD in Spitfire
  This topic is about my 1980 Triumph 1500
Pastor J James Porter
Varnville, South Carolina, USA   USA
This might open up lots of conversation but just seeking others thoughts on it. I had a 78 Spit non OD and drove it well over 200000 miles. It is now history but I pulled the transmission out of it to put in my 1980. It is in the car with new stuff. I have not put the interior in or the bonnet on. I have the transmission from the 1980 and it is an OD. It has several gears bad in it. My question is, in your opinion is it worth pulling out my current transmission using it to rebuild the OD one, buy new seals and such, new drive shaft, or stay with the regular 4 speed? I have never had OD so I don't really know what I am missing. Thanks for your thoughts!!
Fictioneer Avatar
Fictioneer Doug Hirt
Hi James,
If it were me, I'd rebuild and install the overdrive transmission. It makes highway driving so much less buzzy.
Doug
skyking1231 Avatar
Mt. Sinai, NY, USA   USA
+1 to OD. One of my best upgrades...
I have never driven an OD unit either but I think if I had the opportunity I would just rebuild the current unit. More cost but a lot less hassle in getting everything set up right, and you get a new experience.
2manyspits Avatar
2manyspits Thomas Schlundt
south bend, IN, USA   USA
overdrive nice for cruising I am removing from my car cause I'm going to autocross it and they are just too heavy.
Manana Avatar
Manana Steve Wten
Thornhill, Ontario, Canada   CAN
Hey James,
Short of an engine/tranny swap, to me the OD is a no-brainer. I don't take AutoCross as competitively as Thomas does so the weight wasn't even a consideration for me (but a clever one in his case).
Seems that you have a few options and the one I would take would be to get new replacement parts for the overdrive and keep the functioning 4-speed intact. Keep it and the associated parts, mounts, driveshaft, etc. in case something happens to the OD. Easy swap in a day and you can still enjoy the Spit as you repair the OD.
That written, my OD never had any issues in something like 17 years, so maybe I'm just a hoarder!
Not sure what a decent 4-speed would sell for, but I would hope more than the parts you might harvest from it?
Steve
IanF Ian Furqueron
Croydon, PA, USA   USA
My car has O/D and I use it quite a bit. But I also tend to do a fair amount of long trips at highway speeds. Back in the days of the 55 MPH speed limit (when many these cars were new), one could probably survive without O/D. These days when just trying to be safe at modern traffic speeds requires holding 70 MPH or more, O/D is somewhat of a necessity. But... if you avoid highways and mainly do weekend back road jaunts, then O/D may not be much of a benefit other than for resale value.
regnaston Dale Sanger
Hi James,, I also am a Pastor grinning smiley
Question for the rest of you. I assume the OD transmission is a 5 speed manual then? My new to me 65 Spitfire has the GT6 engine and 5 gears
skyking1231 Avatar
OD tranny is different from a 5sp. Btw what is in your 65 ? I guess you have 5 positions on the selector for forward gears?
OD has the 4 forawrd gears...and an overdive unit attached that is electrically operated...which dives overdive in 3 an 4th gear.
I like to consider the overdive gearbox as a 5 1/2 speed... (4 forward gears...4 OD which is like 5th gear...and 3OD...which is similar in ratio as 4th gear)
In reply to # 1496214 by regnaston Hi James,, I also am a Pastor grinning smiley
Not sure exactly what was put in the Spitfire I have.
I know it has the GT6 engine (Not sure from what year) and has a 5 speed manual transmission.
No notes came with it unfortunately
Manana Avatar
Manana Steve Wten
Frank, I think I'd go with a 6-speed comparison. Although the ratio for 3-over isn't an exact step between 3rd and 4th it's actually decently close. I've often used 3-over to just get that sweet spot.
Edit: typo "isn't"
Steve
Edited 1 time(s). Last edit at 2017-11-06 07:58 PM by Manana.
Spitfire Driver Ratios.JPG    31.2 KB
IanF Ian Furqueron
Dale,
What does the shifter look like? If there's a switch on top (or somewhere else) to activate the 5th gear, then it's a Triumph transmission as we've described. If you have to physically shift into a 5th gear, then it is an aftermarket conversion. If the latter, where is Reverse? If up-left, it's a T-9 from a European Ford. If down-right, then it's likely a Toyota conversion.
No button on the shifter
Reverse is push down and far left & up
Just checked again..I guess I was imagining a 5th gear.. only 4
In reply to # 1496246 by regnaston No button on the shifter
Dale,
If you find that you can't select first when the car is moving without grinding the gears you almost certainly have the original three-synchro three-rail gearbox in your car. If first shifts like the other gears then you have the later four-synchro three-rail gearbox.
