Distributor rebuild?
14GPDJENGINEERING Avatar
Silver Spring, MD, USA   USA
Not a big deal. RTFM
The proper way is to use a small pin punch & carefully drive the gear out from the cable side.
Then you can reuse the plug.
A little Loctite will hold it in.
Dennis smiling smiley
Edited 1 time(s). Last edit at 2017-11-01 08:55 PM by 14GPDJENGINEERING.
dplass Avatar
dplass Silver Member David P
Merrick, NY, USA   USA
2011 Ford Fusion
I did as suggested and got the plug out.
Unfortunately now I [url=]can't get the pin out[/url]. Meh. It keeps fighting and I keep losing...
-D
1972 GT6 MK3 "The Beast"
Put the drive gear in the jaws of the vice. Hit the pin with a punch, I am sure you can find it!
Those pins are very tough to dislodge. I usually resort to drilling. Start with a 1/8 inch drill and if necessary work up to 3/16 (the diameter of the pin).
As Tony said clamp the dog in your vise.
Edited 1 time(s). Last edit at 2017-11-03 08:40 PM by 14GPDJENGINEERING.
When going back together I slightly countersink the holes in the dog, use a brass pin, and peen the ends into the countersunk holes.
dplass Avatar
2011 Ford Fusion
Thanks everyone for the advice. I'll try it again.
-D
Greg1835 Avatar
Greg1835 Greg S
Rudolph, WI, USA   USA
When I took the one off my Spit, Dave, I really had to wail on it. Almost seems like it's an interference fit.
It is like a solid rivet on both sides. Grind or file some into the dog to get a better drilling spot and to see the parting line.
You may need to drill from both sides.
Edited 1 time(s). Last edit at 2017-11-04 02:53 PM by 14GPDJENGINEERING.
Clamp the actual dizzy shaft in a plastic jawed vice and use a super fine drift. In a pinch you can fashion a one job tool at the bench grinder from a nail. Hold the nail in vice grips so it doesn't exit - stage left.
In reply to # 1495849 by Doug in Vegas Clamp the actual dizzy shaft in a plastic jawed vice and use a super fine drift. In a pinch you can fashion a one job tool at the bench grinder from a nail. Hold the nail in vice grips so it doesn't exit - stage left.
Doug,
Those pins don't come out that easy. A nail will be too soft to do the job . It will just bend. A concrete nail or one meant to be driven by a powder charge might be hard enough.
Dennis P is right, the pin is more like a rivet, removing the head from one side makes getting it out much easier.
dplass Avatar
2011 Ford Fusion
Update: there is no update. I continued to file down the one side and was able to see the pin, clamped it down, and started whacking with a sharp punch and 4 lb sledge. Still not moving...
-D
In reply to # 1496209 by dplass Update: there is no update. I continued to file down the one side and was able to see the pin, clamped it down, and started whacking with a sharp punch and 4 lb sledge. Still not moving...
'Sharp'?
You need a pin punch like this:
https://www.homedepot.com/p/TEKTON-1-8-in-Pin-Punch-66053/205820407?cm_mmc=Shopping%7cTHD%7cG%7c0%7cG-BASE-PLA-D25T-Garage-Automotive%7c&gclid=EAIaIQobChMI1Z6Fhciq1wIVxbrACh1ZLgnyEAYYCCABEgJ6O_D_BwE&gclsrc=aw.ds&dclid=CMbClZfIqtcCFYmtaQodQeoDTA
Rick in Miami Avatar
Rick in Miami Rick Z
Miami, FL, USA   USA
1973 Triumph GT6 MkIII "Spit 6"
1974 Jensen Healey
On several occasions I have found it necessary to take a distributor to a local machine or auto repair shop to have the factory pin pressed out. On reassembly (make sure the drive dog is properly oriented to your rotor position) I replace the factory pin with a roll/tension pin from the local hardware store.
dplass Avatar
2011 Ford Fusion
Yup, I have this set: https://www.homedepot.com/p/Mayhew-Punch-and-Chisel-Set-12-Piece-61040/203353841
which has almost the same exact punch.
In reply to # 1496215 by clshore
'Sharp'?
-D
Mark Jones Avatar
1995 MG MGF "Barney"
1996 Land Rover Discovery
I was thinking of Jeff as a source for the springs.
In reply to # 1495304 by dplass I'd prefer to do it myself; working on The Beast is my hobby!
In reply to # 1495295 by Mark Jones Try Jeff at Advanced Distributors
1971 Triumph GT6 MkIII
