Carbon Canister
Carbon Canister
  This topic is about my 1978 Triumph Spitfire 1500
GriffinNC Dennis D
Greenville, SC, USA   USA
Anyone have a idea of how much carbon is in the canisters? My carb completely filled them both up when the float stuck and I need to rebuild. Wondering how much fish filter carbon I'll need. Garage is really smelling like gas since then.
You can spread out the old stuff on metal and burn off the gas.
christrish Avatar
christrish Chris B
Lehi, UT, USA   USA
In reply to # 1491019 by Doug in Vegas You can spread out the old stuff on metal and burn off the gas.
Here's the video of John Twist doing this to an MG/MGB carbon canister:
Working to take the "D" out of DPO since 2013
Follow my restoration progress: http://73spitfire1500.blogspot.com
GriffinNC Dennis D
The gas sat in there long enough that the carbon is broke down and mushy. I think replacing the carbon is probably better.
If it has gone squishy then it is dead. The attached might help. I have never measured the actual depth of the charcoal when full but with the filter piece and screen I think you can make a good guess. It is pretty much full.
canister4.jpg    38.8 KB
canister5.jpg    34.6 KB
canister6.jpg    35.8 KB
GriffinNC Dennis D
Most what I'm finding at the pet store is pellets and not busted up bits. They are small pellets still and used for fish tanks. Think it will make a difference.
In reply to # 1491252 by GriffinNC Most what I'm finding at the pet store is pellets and not busted up bits. They are small pellets still and used for fish tanks. Think it will make a difference.
Dennis,
In the carbon canister the important thing is the surface area of the carbon, So the pellets will probably have a bit more area than the chips for the same volume. So they will hold a bit more gas fumes, and maybe take a bit longer to give them up.
Others have commented about using those sort of pellets so as Paul suggests, they should be fine, maybe even better in the long run. You can fill it up to the top just leave enough space at the top for the filter, screen and lid to refit.
Greg1835 Avatar
Greg1835 Greg S
Rudolph, WI, USA   USA
I bought some charcoal from Petsmart and found it was finer than the original. I was able to reuse the original stuff, however. I did find that when I went to refill one, I couldn't get all the charcoal back in. I tapped and tapped the canister but still had about 1/2 cup that wouldn't fit back in.
In reply to # 1491350 by Greg1835 I bought some charcoal from Petsmart and found it was finer than the original. I was able to reuse the original stuff, however. I did find that when I went to refill one, I couldn't get all the charcoal back in. I tapped and tapped the canister but still had about 1/2 cup that wouldn't fit back in.
Interesting. When I redid mine, I burned it off and let it sit in the sun for several hours on a big cookie sheet. It all went back in at the same level as when I took it out.
Greg1835 Avatar
Greg1835 Greg S
Yup, did the same with mine - spread it out on an old cookie sheet, played the torch over it a bit. Mine didn't even have a gas odor and nothing even burned off, so it must have been in pretty good shape. For whatever reason, either the can shrunk or the charcoal expanded. winking smiley Another mystery of the universe.
christrish Avatar
christrish Chris B
Lehi, UT, USA   USA
If you think about how long that canister has been sitting there, being shook/vibrated with every bump and rumble, any voids between the carbon particles would pack down over time. Not surprising that you couldn't get it all back in there. Open it up again after a year or two and I bet you'll be able to pack the rest in there!
GriffinNC Dennis D
I refilled the canisters. As a note one bag of the carbon below is perfect for filling them both.
https://www.amazon.com/gp/product/B000YIWT0M/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
