Spitfire 1500 Wiring loom plan
bazsimoci Avatar
bazsimoci Balázs Kutasi
Várdomb, Tolna, Hungary   HUN
Hi!
I must replace my tired, burned and modified old wiring harness. I just dont want to start with pulling single cabels in the car, and a new loom is pretty expensiv to me...
Then i bougt on the Ebay from USA a very original second hand harness with just few cutted terminals.
I thought i will drawing the harness and measured all the sizes, then later i can made for myself or somebody else can use it as a template. Earlier i didnt find any pictures or description how to do this, then its makes easier to others...
The measures is in mm. This is the part one, i just ended today scetching the part twoo, the wires under the dash.
Here is in larger size:
https://drive.google.com/open?id=0B5zTn4EVjvWPanFDY2pzY2hNN3c
Edited 1 time(s). Last edit at 2017-10-08 12:55 PM by bazsimoci.
PA070003.JPG    29.6 KB
Wow, good luck, looks like something helpful for many in the future.
Good for you Balazsthumbs up
I replaced much of my wiring from salvaged wire from wrecked British cars. Fortunately the British standardized their wire colour codes, so for instance, you can pull wire from a Jaguar and have the right colour wire for your Triumph, and likely in munch longer lengths.
colodad Avatar
Balázs Kutasi, praise the Lord, you answered our question.
We have asked about the ballast wire, where does it come out of the harness, how long is it, how is it connected to the other wires. But no one has yet replied..
I see you have drawn the ballast wire, please take a photo of the harness with wire measurements. post it here.
Thank you in advance for the pictures...
In reply to # 1490803 by colodad Balázs Kutasi, praise the Lord, you answered our question.
Yes, as Calvin says this is the Pink and white wire that connects to the white ignition Wire in the loom.
bazsimoci Avatar
Hi!
Accordings to my calculations the ballast wire is 1630mm long, goes from the starter solenoid with the other cables to the junktion to the dashboard and ended with the white cabel to the PDWA lamp and a white cable from the top fuse.
The resistance is 1,3-1,5 Ohm
PA080008.JPG    74.9 KB
bazsimoci Avatar
It happened what i feared from... The american loom doesnt fit with the european wire extension to the rear harness...
The american loom has two 5-er connector, the european has one 7-er...
And the american ignition switch has 7 connector, the european has just 4...
At least the steering column switches, they fit into their place.
PA080001.JPG    79.4 KB
PA080005.JPG    57 KB
PA080006.JPG    62.5 KB
colodad Avatar
In reply to # 1490994 by bazsimoci Hi! Accordings to my calculations the ballast wire is 1630mm long, goes from the starter solenoid with the other cables to the junktion to the dashboard and ended with the white cabel to the PDWA lamp and a white cable from the top fuse........ The resistance is 1,3-1,5 Ohm
1630mm (64.17323 inches) with your information & image I can find where it in on my loom.
Thank you Balázs, for sorting that ballast wire out and posting the image.
colodad Avatar
In reply to # 1490999 by bazsimoci It happened what i feared from... The american loom doesnt fit with the european wire extension to the rear harness...
yes, and other years have changes too.
That is probably why this information is hard to find, but the ballast wire is a great find.. thanks again..
When I took apart my loom, where (I assume) the resistance wire WAS, there was just melted plastic and bare, green, copper wire!
Strangely the engine still ran.
For most years between at least the early Mk3 and the very late 1500's the wiring is slightly different as far as what is there. In all years it is also obviously different in lengths of the various wires due to the right and left hand drive setups. You have to be cautious on which you use - make sure it matches your car. I will add that many of the circuits are the same as far as setup, just not in wire length. We might even be surprised in how many of those match.
bazsimoci Avatar
There is the second part of the wiring loom drawing:
https://drive.google.com/file/d/0B5zTn4EVjvWPSURrQUVsVVMzc2c/view?usp=sharing
Can anybody say what to do this little box beside of the wiper motor...?
Edited 1 time(s). Last edit at 2017-10-14 08:42 AM by bazsimoci.
Vezetékköteg 2.JPG    41.5 KB
20171014_153557.jpg    19.6 KB
colodad Avatar
I do not have that box.
describe the materials of the box, and should be some numbers on the box.
cwIMG_1889 wiper motor area.JPG    45.8 KB
mkivmarty Avatar
mkivmarty Marty Yanik
N.E.Ohio, USA   USA
That little piece in your hand looks like a ballast resistor. Try to clean the contacts on the ends and get a resistance reading on it.
Marty
colodad Avatar
was this box on the 79 spitfire ?
