Universal Joint
Universal Joint
  This topic is about my 1975 Triumph Spitfire 1500
John J Avatar
John J John B
Kirkland, WA, USA   USA
I'm getting ready to replace the U-Joints on my 75 Spitfire driveshaft. I found lots of posts on the type to choose but there are so many options discussed I was left without a clear direction. What brand model and supplier is recommended for driveshaft U-Joints?
I link would be very helpful there seem to be many choices.
Smithisretired Avatar
Smithisretired Michael Smith
Wells, Maine, USA   USA
The guys at Rimmer Brothers have never let me down yet.
https://www.rimmerbros.co.uk/Item--i-GRID005727
I like SKF, but Hardy Spicer and GKN are also good.
Just stay with brand name parts.
http://www.yoyopart.com/oem/13454489/skf-uj341.html
Edited 1 time(s). Last edit at 2017-09-24 05:59 PM by Tonyfixit.
20170620_181240.jpg    63.1 KB
SpiTazz72 Avatar
SpiTazz72 Bryan H
Magnolia, Texas, USA   USA
I found the type u-joints with the grease fitting that comes out of the center of the cross is a worthless option. The fitting is not accessable without installing an extended length zerk and they can break of easily.
My 2 cents.
John J Avatar
John J John B
In reply to # 1487681 by SpiTazz72 I found the type u-joints with the grease fitting that comes out of the center of the cross is a worthless option. The fitting is not accessable without installing an extended length zerk and they can break of easily.
My 2 cents.
I agree
Has anyone tried these? They seem almost too inexpensive but I like the grease zerk being on the end of the cap.
http://www.autozone.com/powertrain/u-joint/duralast-u-joint/831180_759534_4227
grubscrew Avatar
grubscrew grub screw
My 2 cents.
The zerk doesn't stay in place, it gets removed and replaced with a screw plug.
Dave
1970 Spitfire Mk3
FDU 78359L
TCF 575L
Signal Red/Red interior
In reply to # 1487682 by John J
My 2 cents.
I agree
John,
I have those. Get better quality U-joints. Those seem to give vibration in the drivetrain from new. I think GKN does one with the zerk in the cup.
The UJ I suggested (SKF) and pictured, has the grease zirk in the cap.
greasing is VERY easy, just Plug and Squirt!
NEVER had one fail.
John J Avatar
John J John B
In reply to # 1487772 by Tonyfixit The UJ I suggested (SKF) and pictured, has the grease zirk in the cap.
NEVER had one fail.
Where would I find these? Do you have a link to the supplier that carries them?
In reply to # 1487780 by John J
NEVER had one fail.
Sorry I buy them from our local industrial supply store as I am in Canada, that probably dosent help you much.
You could likely get then from Autozone, Summit of some of the other big sippliers, they are NOT a Triumph specific part. Tip: Don't say you want a UJ for a Triumph! they will only tell you what, if anything, is listed on there computer. Order by part number and specify zirk in the cap.
Greg1835 Avatar
Greg1835 Greg S
Rudolph, Wisconsin, USA   USA
John,
I got some from this seller on e-bay. They are SKF's with the zerk in the cap.
http://www.ebay.com/itm/262505800869?rmvSB=true
John J Avatar
John J John B
Thanks for all your help. I wound up just ordering a set from Rimmer Brothers.
In reply to # 1487919 by John J Thanks for all your help. I wound up just ordering a set from Rimmer Brothers.
What brand are the selling these days?
John J Avatar
John J John B
I think they are Spicer? But won't know for sure until they arrive.
Looking at the part # they could be GKN , which are good thumbs up
I used to keep a 'chamber of horrors' of failed UJ's that I had removed from axels, some only 2k miles old.
Typically the no-names types had a low # of large rollers in the cap, on a small spider bearing.
