Rebuilt head / no compression
Lizzard d id
san jose, ca, USA   USA
In reply to # 1484922 by colodad
In reply to # 1484912 by Lizzard And if you do them one at a time , front to back without the rule of 9s , you don't have a chance of messing up the rule of 9's .
I put a socket on the crank pulley nut, watch the valve close as I turn the crank, adjust that rocker and go to the next one.
That will work on any motor with any number of cylinders . 1 cylinder or 12 , it gets the job done .
SpiTazz72 Avatar
SpiTazz72 Bryan H
Magnolia, Texas, USA   USA
This is what I do. Just remember to remove the socket before starting the engine.
Pats54 Avatar
Pats54 Gold Member Mark M
Maynard, Mass, USA   USA
1979 Triumph Spitfire 1500
Bryan
Rather than rolling the car you turn the crank with a socket, I would think this gives you more control when watching the valves open and close. I will see if I have a socket. I think I have up to 1-5/8. Would you know the size?
Brad.Cogan Avatar
Brad.Cogan Bradley Cogan
Yeah it will most likely be the valve clearances.
Asumming it's had a skim on the head, it's now at a different height and so are your valve clearances.
If the valves are staying a little open during the compression stroke then you'll get very low compression if any.
Just adjust them with a screwdriver, spanners and a feeler gauge.
The only other thing I can think of is the head gasket is buggered
Brad Cogan
Lizzard d id
In reply to # 1484994 by Pats54 Bryan
In neutral with the spark plugs out , you might be able to rotate the crank by hand , or by rotating the generator / alternator .
Las Vegas, Nevada, USA   USA
I printed this and hung it on the wall in the garage.
kaatmanduu Avatar
kaatmanduu Silver Member Mike Stevens
Grass Valley, California, USA   USA
The nut on the crank is a 1 13/16.
In reply to # 1485063 by kaatmanduu The nut on the crank is a 1 13/16.
Two cranks sizes, two crank nut sizes ....
(I don't remember the other one)
Qualicum Beach, British Columbia, Canada   CAN
1976 Triumph TR6 "The Truck"
I assume that the cam TIMING is spot on. The rocker arm gap would have to be way off to get those compression results...
Pats54 Avatar
Thanks guys for the insight I will mic the cam nut for the size.
Rob I would not assume the timing is spot on. I marked the dizzy and the pedestal when I started this mess
But have been moving back and forth trying to get it to fire.
Thanks for the chart Doug.
ExPatBrit Avatar
ExPatBrit Mike W
Redmond, WA, USA   USA
In reply to # 1485151 by Pats54 Thanks guys for the insight I will mic the cam nut for the size.
I think Rob is talking about camshaft / valve timing, if you didn't remove the timing chain you should be fine.
BTW a sheared crankshaft woodruff key can cause weird compression results.
bonnett1954 Avatar
Las Vegas, NEVADA, USA   USA
I got a big 18" Crescent wrench that I use for that job. Slower than a socket but very effective, lot's of leverage.
Pats54 Avatar
Dave yes I guess you are right,
I did not mess with the timing chain.
I guess if the valve adjustment does not work out I can look into that.
But I would not attempt it.
Lizzard d id
In reply to # 1485175 by Pats54 I guess if the valve adjustment does not work out I can look into that.
How soon might you get to the valve adjustment ?
Brad.Cogan Avatar
To adjust the valves, I put the car in top gear, roll it forward and back and when one valve on a cylinder is open, then the other one is completely closed (Eg. If cylinder 1 intake is open then cylinder 1 exhaust valve is definitely closed.)
Then do this for every valve.
Just be careful if you have a mechanical fuel pump as rolling it back and forth will make it pump fuel.
Brad Cogan
1962 Triumph TR4
