Can this be part be replaced?
Simple76 Avatar
Simple76 Bill C
Evensville, TN, USA   USA
1976 Triumph Spitfire 1500 "Simple"
Here is a couple of pics that might help.
IMG_0216.JPG    76.5 KB
IMG_0217.JPG    37 KB
I see two options. 1. cover that bearing area with something easy to get out but that will seal it from grindings, then use a small tool such as a Dremel and do your best to grind that burr back to the shape of the surrounding metal. If you are lucky it is distorted only in the top 1/8 inch or so. If that is true then you will still have some original shape inside of that to match to. Make sure not to grind anything not distorted.
2. drop it all, pull that mount piece off and do the same thing on the bench. The main thing will be to not over cut it and to not grind any area that is not distorted.
teeka56 Avatar
teeka56 mike leisner
Seattle, WA, USA   USA
+1 on Dan's advice. I might be tempted to put a bit of sealant around the outer portion of the seal in the area affected.
( the seal removal /replacement was my least fun things I have done on a spitfire)
Good luck!!!
Mike
josh bowman Avatar
Spring City, TN, USA   USA
1974 MG MGB
1977 Triumph Spitfire 1500 "Spit"
Bill, I'm coming in late here, so forgive me if I'm repeating something. The 2 threads are kind of confusing, but I've been there, you're kind of desperate and need answers. Just to be clear, is the part that dented #1 on the Moss Motors diagram? Spitfire Diff
If that is the part, can it not be just pulled out by prying with a screwdriver and the new seal tapped in? Or is it part of the casting?
colodad Avatar
Grand Junction, CO, USA   USA
In reply to # 1477688 by josh bowman Bill, I'm coming in late here, so forgive me if I'm repeating something. The 2 threads are kind of confusing, but I've been there, you're kind of desperate and need answers. Just to be clear, is the part that dented #1 on the Moss Motors diagram? Spitfire Diff
Josh, he removed the seal, but doing so he was punching the diff case that holds the seal.
now he needs to remove that burr he created.
josh bowman Avatar
1974 MG MGB
Thanks Calvin, sounds like a little metal work is in order.
In reply to # 1477777 by colodad
1970 Triumph GT6 MkII
