Can this be part be replaced?
Simple76 Avatar
Simple76 Bill C
Evensville, TN, USA   USA
1976 Triumph Spitfire 1500 "Simple"
Could not tell what was going on not
enough light not enough room the punch slipped
didn't realize that and I kept swinging the hammer.
IMG_0215.JPG    70.3 KB
colodad Avatar
Grand Junction, CO, USA   USA
yes, looks like a shaft seal ?
Edited 2 time(s). Last edit at 2017-08-12 10:22 AM by colodad.
Simple76 Avatar
Simple76 Bill C
What do I do to replace it?
colodad Avatar
give more info, what is this shaft from ?
Simple76 Avatar
Simple76 Bill C
That is where the pinion seal goes
colodad Avatar
I see your other thread now..
Not the race. The race would be much harder and not mush like that. It is the part that holds the bearing seal.
Best would be to remove the burr with a file, or you will not be able to drive in a new seal wirhout damaging it.
I think you are going to have to remove the front diff carrier.
Simple76 Avatar
Simple76 Bill C
So that means taking the rear end out of the car
colodad Avatar
Edited 1 time(s). Last edit at 2017-08-12 11:04 AM by colodad.
colodad Avatar
photos found..
cwIMG_2107 pinyon rebuild video.JPG    44.6 KB
cwIMG_2108 support removed.JPG    36.7 KB
colodad Avatar
Tony, if a punch did the damage, and a seal is going back in, could he hammer it back to the original position, with the support still fitted ?
then fit another seal, might be tedious but removing the support could cause other problems holding the parts from moving>
colodad Avatar
I don't know how much pounding this part can take before it breaks a piece out of the casting,
the support should be a very close fit, could it help hold it together,
or will he just need to remove some of the metal from inside instead.
Are you just replacing the seal or bearings too ?
Simple76 Avatar
Simple76 Bill C
Just the seal
colodad Avatar
as suggested on your other thread, don't let grindings or metal slivers into the bearing when doing work. Cover the bearing with some cloth.
I think you can fix this, we can't see the inside so is it just a burr or has the metal pushed into the opening behind the burr ?
Simple76 Avatar
Simple76 Bill C
Just a bad burr I think it will bend back not sure just needed more advice
1964 Triumph TR4
