Overflow bottle overflowing, while thermostat housing dry. In GT6 MK1 original euro setup.
RolandB Avatar
RolandB Roland Beernink
Eindhoven, NB, Netherlands   NLD
Jim,
You might be on to something.
I measured the depth, and compared it to the Cap. And it s very close. (seems 1mm short).
But when putting the cap on you its pushed slightly to the inner ring.. But might not be enough.
I can see marks on the rubber that it’s at least is touching… but might not seal enough for the pressure.
Added some pictures..
I am already in the process of head replacing.. as there was low compression in 2 and 3 .. (so that can’t hurt..).
And I will start searching for other caps.
Lizzard.
Sure It will fit ? you have to share the space with some vintage suitcases back there!
Sorry no Mousehole this year , done that a some years ago. This time its going to be the lake district (cumbria) , is that ok for You ?
Roland
IMG_6127.JPG    39.4 KB
IMG_6128.JPG    49.7 KB
Lizzard d id
san jose, ca, USA   USA
RolandB Avatar
An update, on water overflowing the bottle,
I have spent last week, getting the head of a spare engine i ran into a few month ago..
Drilled out a broken off stud,
And get it machined with new valves, and valve seats are re ground.
I double checked if it is identical as the current head when i removed that, and it was luckaly a perfect match.
Then i ran into a problem i could not get one bolt to reach the torque... (i stopped before i broke something.).
Replaced the (long) studs. and all nuts...
And yesterday i was able to drive it again,
I did a cold compression test (Should be worm I think).
Before compression was average 159 psi (with max 175 and lowest 140).
After compression average is 193 psi (with max 195 and lowest 185)
I was not successful yet in finding a higher radiator cap.
I short drive yesterday 40KM 25Miles. At 30c degrees ,( 86F ?).
The water bottle seemed pretty stable. No overflowing.. just seem to rise a couple of Centimetres. (1 inch or so).
It look like it worked, and the radiator cap does not seem to be replaced.
The holiday seemed to be saved.. (after I fix the Horn which stopped working yesterday)…
Thank you all for your input!
Roland
J.P.Rap Avatar
J.P.Rap J.P. Rap
Mount Hope, Ontario, Canada   CAN
1976 Triumph 1500 "Donna"
2007 Ford Ranger
Congratulations Roland. Glad to hear you got it figured out. Hope you have a trouble free vacation.
Ive had to repair my horn 4 or 5 times this year and each time it's a different problem. What a PITA.
Lizzard d id
In reply to # 1465155 by RolandB Then i ran into a problem i could not get one bolt to reach the torque... (i stopped before i broke something.).
I don't like that , why doesn't it torque up ? You really need to have them all torque up good .
In reply to # 1465155 by RolandB The holiday seemed to be saved.. (after I fix the Horn which stopped working yesterday)…
RolandB Avatar
Hi Lizzard ,
I am having trouble understanding my own post too..
What I meant to say was that after I replaced the studs with new studs and new nuts. I was able to get it up to torque perfectly.
Roland
Lizzard d id
