Wheel spacers
MTBer Adrian Tayne
Grants Pass, OR, USA   USA
1967 MG MGB GT
1970 Triumph GT6+ (MkII) "Chloe"
I designed and built wheel spacers for my GT6 project because the Cosmic alloy rims interfered with brake calipers. With the longer Rover studs, there is lots of stud length left over to add the spacers. They fit both front and rear.
My question is if there is a demand for these spacers to solve issues resulting from using alloy rims.
0908162110_HDR.jpg    27.1 KB
Spacers are always useful for fine tuning the effective offset.
Nice job, were those waterjet/laser cut?
Would be childsplay to use different thickness material as required.
That said, the caliper castings have plenty of 'meat' around the outside, enough that
grinding material away to clear wheels for fitment is a viable approach.
Just sayin' ....
Carter
MTBer Adrian Tayne
1967 MG MGB GT
Carter, thanks. The intention was to have them run on the waterjet but it was down the day they tried to run them so they were CNC milled instead. I used 1/4" 6061-T6 for these particular spacers but as you say they could just as easily be cut from any thickness of material.
SS2013MaxTow Avatar
SS2013MaxTow Silver Member Steven Slay
Ovilla, Texas (TX), USA   USA
very nice looking!
MTBer Adrian Tayne
1967 MG MGB GT
I was just looking at these today and thinking about how I need to offer them to the forum if anyone is interested
Manana Avatar
Manana Steve Wten
Thornhill, Ontario, Canada   CAN
Hey Adrian, they do look nice.
I may be missing something here though; seems to me most (read almost all) Spit/GT6s with alloy wheels and slightly wider tires suffer from them sticking out too far (up front, rear seldom an issue); will this not exaggerate that?
Steve
MTBer Adrian Tayne
1967 MG MGB GT
Time will tell. The reason I made them is the old Cosmic rims don't clear the brake calipers without them. I haven't mounted the body yet to find out whether there is a clearance issue between the tire and the fender.
Spitfirejoe Avatar
Spitfirejoe Joe Guinan
Fremont, Nebraska, USA   USA
Which Cosmic rims are you using that don't clear the brake caliper? Asking because I have a couple pair that I haven't mounted yet.
Joe Guinan
Fremont, Nebraska
MTBer Adrian Tayne
1967 MG MGB GT
5.5x13 MK1
1512318750339635617600829033676.jpg    52.4 KB
Manana Avatar
Manana Steve Wten
Cool rims, I hope it works out. thumbs up
Steve
Las Vegas, Nevada, USA   USA
That's a lot of crannies to clean.
claytoncnc Avatar
Those wheels certainly fit Spitfires, I used them for many years.
Interesting they do not fit your GT6, as I have a recollection of lending them to a friend for his GT6.
Spitfire Mk3 1.jpg    42.6 KB
Spitfire Mk3 3.jpg    41.7 KB
Spitfire2 75.jpeg    25.9 KB
Depending on the actual wheel width and offset, there is a well known issue with wheels contacting the 'ears' of the upper wishbone
where they bolt up to the upper ball joint.
The solution is simple and straightforward:
Grind away and smooth the outer portion of the 'flanges' to provide clearance.
https://www.rimmerbros.co.uk/Item--i-119272
https://www.rimmerbros.co.uk/Item--i-119272U
MTBer Adrian Tayne
1967 MG MGB GT
Those are some wild pictures. Possibly the only pictures I've seen of these wheels mounted to a spit or GT6, certainly the only ones I've seen doing donuts!
claytoncnc Avatar
In reply to # 1501219 by MTBer Those are some wild pictures. Possibly the only pictures I've seen of these wheels mounted to a spit or GT6, certainly the only ones I've seen doing donuts!
It was only 42 years ago
I had a lot more hair in those days
That is me in the white T Shirt, The other bloke, is now a retired lawyer who has a vineyard, and makes award winning wines.
The car has Cosmic mk2s and belonged to another friend who still comes out for a drive on Sundays, though now he has a big Healey.
Spitfire 1.jpg    47.6 KB
1976 Triumph Spitfire 1500
