VIN Number
drdaws Don D
Orange, CA, USA   USA
I have a 1972 Spit, the DMV is disputing the VIN number. Is it the stamped number on a small rectangular plate visible thru the windshield (drivers side) or the plate attached to the body, drivers side, under the bonnet? I've registered this car for the last eight years, now I'm having a problem! thank you.
kaatmanduu Avatar
kaatmanduu Silver Member Mike Stevens
Grass Valley, CA, USA   USA
Someone at DMV saw the odd VIN, and said 'That must be wrong'. The VIN is on the windscreen tab. My '74 also has it on the drivers door B pillar.
ExPatBrit Avatar
ExPatBrit Mike W
Redmond, WA, USA   USA
Triumphs don't have VIN numbers until very late in the run 79-80 ? , often confuses DMV and insurance companies .
Triumph Spitfire identification
Edited 1 time(s). Last edit at 2015-07-10 02:12 PM by ExPatBrit.
Born Loser Avatar
Land O Lake, FL, USA   USA
Correct, the windshield and the tag in the door - they should match. And they are NOT VIN numbers, they are commission numbers. The one under the bonnet is not related, and not referenced in you title work. When I brought my car to Florida, the county would not issue a title, telling me Ga got it wrong. I had to get a special State inspector to verify the commission number.
Matthew
1960 Triumph TR3a
1970 Triumph Spitfire MK 3
2018 Jaguar F-Pace
Erics79spit Avatar
Erics79spit Eric Fanning
Moorhead, MN, USA   USA
I have a 79 spit built in 78 looking at the comm # it seems like i need 78 replacement parts ????? help
What parts are you talking about?
Our cars tended to meld into the next model year, fortunately most parts are interchangabel between years. Unless you are entering concourse or need certain components that must match related components it seldom matters.
Just like current processes, the 79 model year cars were first sold in Sept of 78 and will have a 78 build date on the commission plate. It is still a 79 of it has a commission number above FM95001 for US market cars.
Erics79spit Avatar
thats the problem my 79 is fm91680u?
Erics79spit Avatar
Buying a fuel pump they sell them as 73-78 and 79-80 thats my I cant chooseconfused smiley
Yours is actually a 79 model so order that way. Check this page from The Roadster factory.
Edit 11/12/17. My error and apology- My typo above. if your number is only 91xxx then it is actually a 78 model car as the 79 did not officially start until FM95001. It may have been originally titled as a 79 due to it sitting on the lot into the new year when new. It does not happen now but apparently did back in the day.
Edited 2 time(s). Last edit at 2017-11-12 01:25 PM by Yellowhawk Valley.
1500 fuel pumps.jpg    46.2 KB
Erics79spit Avatar
thanks dan
In reply to # 1302242 by drdaws I have a 1972 Spit, the DMV is disputing the VIN number. Is it the stamped number on a small rectangular plate visible thru the windshield (drivers side) or the plate attached to the body, drivers side, under the bonnet? I've registered this car for the last eight years, now I'm having a problem! thank you.
Next stop is your FLAPS where the kid asks if that "Triumph Spitfire" you mention is made by Buick.
Eric, the other location, other than the windshield, for the Commission number is as shown here. The numbers in both places must match or they won't be nice to you/.
Comm plate.JPG    57 KB
Why am I reminded of this?
1964 Triumph Spitfire 4 MkI
