Need help tr4a rear diff size measurements
bteichgraber Avatar
Tsawwassen, BC, Canada   CAN
Need help, can someone please confirm these measurements - i was under the impression that the pinion is on centre.
I bolted two straight bars to the wheel flange and measured inside to inside , I then measured inside of bars to centre of pinion flange. The measurements don’t add up .
Regardless I need to figure out my centre to wheel flanges.
Edited 2 time(s). Last edit at 2017-11-20 09:07 AM by bteichgraber.
Screen Shot 2017-11-19 at 8.52.24 PM.jpg    15.6 KB
I don't know the exact differences for a TR4A solid axle, but I can confirm the pinion shaft is slightly off-center. For TR2-TR4 though, the offset is only about 3/8" (meaning the measurements would differ by 3/4"winking smiley.
BL50 Avatar
Grosse Pointe, Michigan, USA   USA
Brian,
I measured wheel flange to wheel flange on mine and got 49-5/16". Then I measured from the outside edge of the backing plates to the center of the pinion and got 23" on the left side and 22-3/4" on the right. Everything is snug but nothing is torqued to specs yet.
Hope that helps.
Brian
IMG_1814.JPG    47.2 KB
bteichgraber Avatar
Something caught my eye on your shaft housings - nearer to the pumpkin where the shaft housing goes into the diff housing there are marks on the shaft housing . On mine one is right on the diff housing while the drivers side is as what yours is like, out about by 1/2”.
50DBA77B-5742-4C67-8A5B-A73561713F0E.jpeg    53 KB
bteichgraber Avatar
Someone else sent me this.
It looks as if the consistency of our british cars parts are off, I guess by the fellow who did or did not have his cup of tea when being made ...
AC182504-6164-47F8-B41F-FE8B8BFFBB76.jpeg    27.1 KB
bteichgraber Avatar
Is this what you meant - correct ?
A512A02E-A91E-4954-9130-54B43AE09E67.jpeg    50.2 KB
BL50 Avatar
Yes.
From the workshop manual
untitled.JPG    53.4 KB
untitled.JPG    4.9 KB
bteichgraber Avatar
I was able to pull out my old rear end and measure it - in the pick.
0207FE2B-B6B3-487A-9804-F0296B1179ED.jpeg    20.9 KB
johnstydo Avatar
johnstydo John Styduhar
Hermitage, PA, USA   USA
I would love to convert my TR6 to a solid rear axle and get rid of that clunky IRS.
