replacing transmission
jwade David B
Stony Point, NC, USA   USA
I am currently replacing a transmission in my tr4 with a correct 4 speed for a TR4, it had a TR6 transmission in it that had problems. When I pulled it out I found out that it had a diaphragm clutch so the clutch is incorrect also.
I have a spare engine with the correct flywheel and pressure plate on it. I understand that in order to change the pressure plate I need to change the flywheel. Is this correct? Should I change out the flywheel and pressure plate ?
Normally yes. The later (TR4A onwards) diaphragm clutch takes a different bolt circle than the earlier "finger" clutch. But it is possible that someone had the earlier flywheel redrilled to accept the later clutch; meaning the holes would still be there for the earlier one.
Either setup works well enough, IMO. I had a 4A style clutch in my former TR3A for about 50,000 miles and it worked fine. Showed no significant wear, so I moved it to the current TR3 without even changing the friction plate; where it's done probably another 50k or so with no problem. The 4A clutch is slightly lighter and smaller as well, so it gives just a bit better performance in lower gears.
Geko Avatar
Geko Stef SG
If you have the complete setup for a 4A I would keep it for the reason explained above + you won't have any problem to find the spares
1979 Triumph Spitfire 1500
