new clutch
new clutch
  This topic is about my 1967 Triumph TR4A
Hayesman64 Avatar
Hayesman64 Jere T
Westhampton, NY, USA   USA
good morning members,
just had original transmission redone at Quantum mechanics in Ct.
i am going to have a new clutch put in same time.
my question is spring clutch or diaphragm clutch?
i have a 67 TR4A.
thanks for any input,
JT
Jere, are we talking cover or clutch?
The cover will be the one with the different type of operation. The spring type is original and works fine, some find the diaphragm ones to be a little smoother. Can't say I noticed enough difference in a daily driven to have a preference.
Some have had trouble with the diaphragm type working with the normal push rod on the slave and had to go with a adjustable one. (longer)
Geko Avatar
Geko Stef SG
That would be diaphragm type, you don't have the choice
A stock 4A takes a "diaphragm" clutch, similar to TR250-TR6. To fit the TR4 style clutch will require other changes, like fitting an earlier flywheel (or having yours machined to accept the early clutch) and using the earlier TOB and carrier.
Hayesman64 Avatar
Hayesman64 Jere T
Diaphragm clutch. thanks for the info everyone.
JT
1980 Triumph TR7 Drophead
