Clutch metal line from clutch master cylinder to plastic line from slave cylinder
61bugeye7273mg Avatar
61bugeye7273mg Jeff Wagaman
Hanover, PA, USA   USA
Is it ok to run a 3/16" Clutch metal line from clutch master cylinder to plastic line from slave cylinder? The one that was on, was 1/4"? I have Iine and fittings to make it with 3/16 line but would need to order 1/4" size. Any thoughts?
Thanks for help!
Jeff
I can't see why not. On a TR3, it's 3/16" metal all the way, except for the short rubber piece at the slave. Seems to work fine with my TR6 clutch.
1964 Triumph Vitesse
