TR4A Seat Rebuild Instructions - Attached
Desert TR Avatar
Desert TR Gold Member Jim P
Albuquerque, NM, USA   USA
In the process of setting up to redo my TR4A seats I searched for any available instructions. Not only did I not find any, I wasn’t even able to find instructions for the kits required for the rebuild. The TR4A is different from both the TR4 and the TR6. Even then the instructions I found for the TR6 were somewhat simplistic. I couldn’t even find detailed pictures of completed seats. The closest was the John Skinner site, but even these were inconsistent. (Check his photo gallery and compare the light blue with dark piping set with the medium blue set and you’ll see what I mean.)
The covers on my seats were replaced with home made ones when sets weren’t yet available, but the foam on the passenger seat, while degraded, was still original and as installed by the factory. Using this as a model, I rebuilt the seat and used the opportunity to create a step by step instruction guide for the TR4A seat that others might be able to use. I’ll state up front I’m not an upholsterer, but have helped put in a few interiors. (Mostly hog ring and wire type)
The attached instructions may not be the way a professional approaches it, but, good or bad, I did end up with a completed seat. They may well be over detailed, but I decided it was better to include too much information and too many photos than not enough. I also included mistakes I made along the way. spinning smiley sticking its tongue out The instructions have been broken into sections to accommodate the site’s file size restrictions. Please feel free to ask questions or make comments and suggestions.
I apologize upfront for any typos…
Jim
Edited 1 time(s). Last edit at 2016-03-07 06:39 PM by Desert TR.
039.JPG    42.9 KB
Triumph TR4A Seat Rebuild A.pdf    2.35 MB
Triumph TR4A Seat Rebuild B.pdf    2.36 MB
Desert TR Avatar
TR4A Seat Rebuild Instructions Part 2
Triumph TR4A Seat Rebuild C.pdf    1.95 MB
Triumph TR4A Seat Rebuild D.pdf    2.06 MB
BL50 Avatar
Grosse Pointe, MI, USA   USA
FANTASTIC!
Thanks Jim! My seat kit from TRF just arrived today. Your hard work and attention to detail will save me many hours I'm sure. Thanks again for your help.
Brian
Hayesman64 Avatar
Hayesman64 Jere T
Westhampton, NY, USA   USA
JIM,
I HAVE THE 67 TR4A. NEED TO DO THE SEATS. YOUR INSTRUCTIONS ARE TERRIFIC. THANKS A MILLION FOR POSTING.
IN YOUR FIGURE 69, DO YOU KNOW THE PURPOSE OF THAT SEAT CLIP ATTACHED TO THE RUBBER BUMPER?
JT
Fictioneer Avatar
Fictioneer Doug Hirt
Ditto on the thanks. Your time, effort, and details are really appreciated. I'll be printing this out and putting it in my folder for the time my seat rebuilding comes around.
Desert TR Avatar
JT,
That clip (blue arrow) is meant to clip onto the top of the seat track mechanism. It is designed to keep an empty seat from tilting forward during braking, etc. They are know for breaking off during use and I only have one myself.
I hope the instructions work well for you. Just remember, it still takes a bit of work and a lot of patience. Walk away and take a break when you get frustrated (and you will!). I refer to using heat. Keep it to what you might expect on a sunny day. (Steam works better, but I, like most, don't have that kind of equipment.)
Jim
BraxtonO Avatar
Raleigh, NC, USA   USA
Jim,
Great detailed instructions. I'm not quite to the point of re-doing my TR4A seats, but I will have to before long. Foam crumbling out and back card holes pulled out, such that the back cards gap open at the top and sides.
I've saved your instructions on my iPad - all four sections. I can't imagine a better guide.
Thank you so much for doing this. Your attention to detail shows in the great results on your own seats. But also in these fantastic instructions.
Much appreciated.
Braxton
Hoover, AL, USA   USA
Great instructions. Thank You !
5141941 Avatar
5141941 Gold Member John McLaughlin
Somerville, MA, USA   USA
winking smileyThis will be the second seat rebuild on my 4A . I was dreading the rebuild till I found these instructions. When I finish I'll post a few pics. It'll be a while ,have to build up reserves of PATIENCE.
5141941 Avatar
Progress so far thanks to the instructions and PATIENCE
DSCF1974.JPG    56 KB
5141941 Avatar
More, the cleaning of the frame, old adhesive residue and a little surface rust at the bottom, took the most effort so far.Painted yesterday and let set in the sun. I think the next bit will be most difficult. I have new burlap and batting.Not sure if the batting is thick enough. Will do trial fit before gluing up. I'm using the MOSS seat cover kit and, I find there is no pocket for the tension spring. Has anyone experienced the same?
Edited 2 time(s). Last edit at 2017-05-22 10:58 AM by 5141941.
DSCF1975.JPG    44.6 KB
5141941 Avatar
I've sent the Moss kit back. Moss didn't have an explanation for the lack of the tension spring pocket. DELAYS, DELAYS!confused smiley Ordered The Roadster Factory seat kit
Edited 1 time(s). Last edit at 2017-05-23 01:14 PM by 5141941.
Desert TR Avatar
John,
The tension spring is important. It's kind of like wearing pants without a belt. If you sit there's a good chance people will see the crack! smileys with beer I will point out that TRF has their kits built to order in Suffolk, England, so it will be awhile before you get it.
Jim
5141941 Avatar
Well said. I didn't think of it that way.grinning smiley
5141941 Avatar
Got an email from TRF. The delay is 8 weeks ! Hope the order will be completeeye popping smiley
1969 Triumph GT6 MkII
