TR2 & TR3 Photos and Videos Thread
Westendclassic Avatar
Westendclassic Simon Trewin
London, London, UK   GBR
1960 Triumph TR3A "SCOUT"
1960 Triumph TR3A "Scout - The Convict's Car"
1972 MG MGB "BEAN"
I have been restoring Scout for a year yet and have yet to drive him more than fifty metres into the garage. Can't wait to get on the road and test him out!
Simon Trewin, London UK. Current fleet comprises a 1971 MGB Roadster called BEAN and a 1960 TR3a called SCOUT
image.jpg    32.6 KB
image.jpg    53.6 KB
image.jpg    55.9 KB
image.jpg    79.4 KB
BillyB62 Bill Hall
Moosup, CT, USA   USA
Simon!
Nice to see you back on the forum! I'd be interested to see how you sorted out your dash.
Bill
TS63273L
The car looks great btw!
1972 MG MGB "BEAN"
Great timing - am sorting dash out today! One major question - the main grounding cable that comes directly from next to the battery has to be connected to the dash according to my diagram but I am unsure where or how. Any help please?
Much appreciated.
image.jpg    28 KB
image.jpg    49 KB
Jacad Avatar
Montreal, QC, Canada   CAN
Simon,
The screw clamp in the dashplate is where you attach the grounding wire .
Barry
Edited 1 time(s). Last edit at 2016-09-11 07:16 AM by Jacad.
dashplate.jpg    38.1 KB
BillyB62 Bill Hall
Moosup, CT, USA   USA
Thanks for chiming in Barry - I was out-and-about all weekend and just getting back to the forum.
Simon,
Got questions, ask away - I just put a new wiring harness this Spring so things are still pretty fresh.
Bill
TS63273L
firsttimeownersimon Avatar
firsttimeownersimon Simon Trewin
1972 MG MGB MkIII "MGBean"
Brilliant thanks for note re clamping position - will figure out what clamp to use now!
Also there is a dangling loose cable attached to one of the positive terminals on the Lucas coil. Opinions and wiring diagrams differ as to whether this goes to ignition switch or to fuse box. Thoughts gentlemen please!
Simon Trewin London UK
MGB Roadster 1971 Bean MHS577L
TR3a 1960 Scout 331UYP
Jacad Avatar
Simo,
The clamp is a no brainer, it is built in to the dashplate and there should be a slotted screw threaded into it which serves as the clamping mechanism.
Not sure about the dangling wire you describe however, You should have a white wire coming from the fusebox terminal #A3 and attaching onto the plus terminal of the ignition coil. Then on the opposite side of the coil a short white with black wire running from the negative terminal to the distributor terminal post. There should not be any other wires attached to the coil terminals.BTW, the 2nd fuse circuit with the #A3 and A4 terminals only becomes "hot" (energized) when your keyswitch is turned to on.
Barry
24KARAT Platinum Member BOBBY VENNIRO
CLEARWATER, FL, USA   USA
car looks great, where did you find the battery bracket and water bottle ?
Stearman22 Avatar
Stearman22 Jeff Campbell
Dana Point, CA, USA   USA
Left to die in an old garage, assumed by a family member to sit quietly for another 20 Yrs. Finally purchased by me. Many things to do but it's a got solid California bones and compression in the cylinders. I will keep adding to this post!
image.jpg    43.5 KB
Boot neck Dave Avatar
Boot neck Dave David Orme
Wakefield, Yorkshire, UK   GBR
Well one year on 2400 hrs plus and getting there, another 2 weeks and froggy will be completed, ha, i said that two weeks ago, then starter failed, then uncovered the leather binding to the steering wheel, urg crack , crack O well another 10 hrs of work, there are some of you out there that herd me say last year that i would take 5 months to rebuild Froggy, well I failed .why didn't you worn me.
1440237046009.jpg    63.8 KB
IMAG2260.jpg    56.9 KB
IMG-1468583835962-V.jpg    64.2 KB
20161015_150103.jpg    69.5 KB
M. Pied Lourd Pied Lourd
ON, Canada   CAN
Well....I guess you are never truly "finished" working on a TR, but I am calling this one done for now! Just finished it a short while ago after a 5 plus year restoration...it's a blast to drive!
Tush
image.jpeg    78.3 KB
image.jpeg    48.5 KB
image.jpg    50 KB
image.jpeg    54.6 KB
Looking good, any pics of the engine bay area, 5 yrs what's next ??
ON, Canada   CAN
In reply to # 1408361 by Boot neck Dave Looking good, any pics of the engine bay area, 5 yrs what's next ??
Thanks Dave. Lots of videos on my YouTube Channel.....my channel name is cheftush.
I'm now working on a 1959 TR3A. That will be followed by body off restorations of a 1981 TR8 and a 1968 TR250 that are waiting in the wings.
Tush
Taking scout's nose off today!
image.jpg    78.8 KB
image.jpg    60.8 KB
My engine is going off to be rebuilt next week. Here is the before picture...
image.jpg    81.4 KB
image.jpg    51.2 KB
1973 Triumph TR6
