What did you do with your TR2/TR3 today?
jerburke Avatar
jerburke Jeremy Burke
La Habra, CA, USA   USA
When I first bought this car, a few weeks back, I noticed the car pulled to the right when applying the brakes. Also noticed the E-Brake was t working properly.
So I decided to get it up on jackstands and do a full brake job this weekend.
I also greased all the fittings and checked the rear end fluid.
I'm waiting for the calipers to be rebuilt.
Up next will be an oil change, and check the transmission gear box fluid.
-Jeremy
1960 Triumph TR3A - Originally purchased new by my Grandfather
1929 Ford Coupe Hot Rod - Family Owned Since 1966
1929 Ford Roadster Pickup Hot Rod - Father/Son Project
2007 Toyota Fj Cruiser - Original Owner
IMG_5101.JPG    42 KB
tonytr3 Avatar
tonytr3 Tony M
Grosse Ile, Michigan, USA   USA
I replaced a leaky rubber fuel line between the main feed and pump. When I cleaned up the spilled petrol I then installed a spin on oil filter adapter.
IMG_20170830_112524401.jpg    33.4 KB
parkerg1 Avatar
parkerg1 Gary Parker
Grand Island, Ne., USA   USA
1951 MG TD
1961 Triumph TR3A
1998 BMW Z3
On the way to the farm, for a long winter nap. Always kind of a sad day when the driving time is done for the year. Took it's last ride yesterday, filled the gas tank, and added stabilizer. Then into the trailer to go into the storage building. I need to take one car out of the garage, so I can close the door between the garage and shop, and turn the heat on in shop.
Gary
TR-in-Trl.-web.jpg    44.8 KB
tonytr3 Avatar
tonytr3 Tony M
Scraped half a bucket of crud off the frame. Yuck. Then I put it up on jack stands (did the scraping while it was up on the lift) and removed the wheels and tires. Took them to Belle Tire to have the 18 year old tires removed and scrapped. The wheels will be blasted and powder coated before it gets new rubber.
Starshark Avatar
Starshark Joe Garcia
Gainesville, Georgia, USA   USA
1960 Triumph TR3A "White Knight"
Polished my SUs...clean enough!
20171105_111538.jpg    39.4 KB
20171105_101451.jpg    44.1 KB
20171105_101456.jpg    35.3 KB
20171105_111640.jpg    44.5 KB
ts2183o Marc H
Ashburn, Virginia, USA   USA
Looks great, can you do mine now!!
jerburke Avatar
In reply to # 1496773 by ts2183o Looks great, can you do mine now!!
I was thinking the same thing!
They came out really great!
-Jeremy
ColinGrey Colin Greyvensteyn
Cape Town, Western Cape, South Africa   ZAF
I had the task of repairing the radiator.
Somehow feel like it's not quite a one man job but managed nonetheless, in and out in two consecutive days
1957 Triumph TR3A
1967 Triumph Spitfire
1932 MG J2
1926 Lancia Lambda
1932 Austin 7 Ulster Replica
1971 Kawasaki H2
1976 Honda CB550
1962 Vespa Primavera
8a4b77cc-d4e8-48f6-912b-2962f40dc3c5.jpg    44.9 KB
d7473ea1-e75a-4cc8-97df-ed09d12f544a.jpg    41 KB
Screen Shot 2017-11-09 at 01.33.54.jpg    37.3 KB
Starshark Avatar
Good going...just did mine as well...but kept the hole for crank starting. It was a decomposing mess the core was ok...and I just had reconditioned in Santa Clara California in 1975...got my money worth huh. In the US eBay, a reconditioned radiator with crank hole will go for $550...I had mine fixed locally by an 80 year old at Lester's Radiator shop for $95. I recommend to replace your fan with a "Hurricane fan" from Mark Macy's "Macy's Garage", Tipp City Ohio USA.
Joe
20160219_170527.jpg    49 KB
20160221_123200.jpg    42.6 KB
20160229_155330.jpg    36.1 KB
20160605_140632.jpg    40.9 KB
alexwoof Avatar
alexwoof Roger Bean
marquette, michigan, USA   USA
My new project 62 tr3B. The long winters in northern Michigan just got more tolerable.Starting out with the floor pans
Have a great day. Roger
CF856829-ACC1-458D-9EE5-B81E3ABCF2AE.jpeg    72.9 KB
23FCFD00-F0AA-4015-BCF5-FC813222E9BC.jpeg    51.9 KB
9F288373-0C74-4697-B531-BF80316F6867.jpeg    44.2 KB
D10295F3-B909-40FA-98E9-82B96973A8F6.jpeg    51.2 KB
Starshark Avatar
Love your roll bar...Had my for 40+ years...messes up the top down profile of the car but gets to be invisible when the top is up.
Motivation: Had to install it when my Navy buddy rolled his MGB...took his head off...Still have my head...but if I should roll the car...who knows...might lose it anyway???
Looks "ok" with tonneau on though.
005.jpg    43.8 KB
20170430_123312.jpg    54.3 KB
20170529_132851.jpg    35.7 KB
tonytr3 Avatar
tonytr3 Tony M
Removed the brake pads, with a little help from a screwdriver and a pair of vice-grips. Broke one of the "plate, pad retaining/spring, anti-rattle" bolts. It turned as easy as the three others that came out, but the head just turned off. That caliper also has a bleeder that was broken off by the previous owner, and both pistons are frozen, so I have a bit of work or expense.
tonytr3 Avatar
tonytr3 Tony M
Removed the calipers.
Trusty Paul Monette
Bad Homburg, Hessen, Germany   DEU
Tony, I assume the pistons will be frozen. Keep us posted on how you get them out. I’ve tried lots of WD 40 but it hasn’t helped. Calipers are sitting in a box, it’s a job I’ve put on hold for now. Paul
tonytr3 Avatar
tonytr3 Tony M
One piston on each caliper came out with air pressure. Put that one back in and clamped it. The other piston, on both calipers, moves a tiny bit, but will not come out. Have both soaking with Kroil. Will post final results.
tony
1976 Triumph Spitfire 1500
