are there two of this bracket?
brucejon Avatar
brucejon Bruce Jones
Santa Cruz, CA, USA   USA
1969 Triumph Spitfire MkIII
1972 Triumph TR6
Ok, after getting sidetracked replacing heater hoses I am installing the rest of the steering bits. As I get to the passenger side I am thinking there ought to be this same bracket as on the drivers side. (newly painted in the picture). I can't find it in the parts catalog diagrams (either side). It wasn't there when I took it apart. Can someone tell me if it is on both sides? If so anyone have an extra? I guess I could make one, but it would be nice to have an original.
WP_20180213_12_49_43_Rich.jpg    34.2 KB
Geo Hahn Avatar
Mt Lemmon, AZ, USA   USA
Only one (on the outboard side) on mine.
The hole you may see on the inboard side of the frame will be used to mount the radiator guard.
brucejon Avatar
1972 Triumph TR6
Is there one on the outboard side on the passenger side? The one I have is drivers side
tr3hardtop Avatar
tr3hardtop Colin Gentle
Bethel, CT, USA   USA
When I took my TR apart I had one of those! Even have a photo of it on the chassis, it was on the out board side. Well even though I bagged and tagged everything it has managed to escape.
If some one has an extra one of those they would like to sell let me know, or dimensions to fabricate one.
Cheers,
Colin
1961 TR3A TS/81208-L-O
Geo Hahn Avatar
In reply to # 1513186 by brucejon Is there one on the outboard side on the passenger side?
Sorry, I did not realize the exact spot you meant - but the answer is still the same, only the one on mine.
I agree; only one. It's meant to reinforce the tower that carries the steering box. The idler arm takes much less force and doesn't need to be reinforced.
Easy enough to fabricate; you can pick up some steel at Home Depot, bend to shape and drill appropriately.
Oh, BTW, I just noticed it is installed wrong. That bracket should be turned over the other way so it sticks out away from the frame. The frame extension (to the front apron) and a small spacer both have to fit between the bracket and the frame. Then there is a single long bolt that goes through the bracket, spacer, frame, and radiator guard.
brucejon Avatar
1972 Triumph TR6
In reply to # 1513279 by TR3driver Oh, BTW, I just noticed it is installed wrong. That bracket should be turned over the other way so it sticks out away from the frame. The frame extension (to the front apron) and a small spacer both have to fit between the bracket and the frame. Then there is a single long bolt that goes through the bracket, spacer, frame, and radiator guard.
Randall, I don't see all that - the radiator guard and a frame extension to the front apron, in Geo Hanhs picture in the other post. Am I looking at it wrong? Btw I bought the car with the front apron off, so I may be flying a bit blind if there was an extension or other bits the PO removed.
Geo Hahn Avatar
In reply to # 1513314 by brucejon ...I don't see all that - the radiator guard and a frame extension to the front apron, in Geo Hanhs picture in the other post. Am I looking at it wrong?
Here is that photo of mine:
and yours...
Something's not right here.
Maybe this will make it clearer.
(1) is what I call the frame extension (SPC calls it "Bracket assembly, bumper support - L.H." 606515)
(2) is the radiator guard (aka "Cross-member, radiator protection" 109487)
(3) I think is the bracket/brace we are discussing (aka "Bracket, stiffening, trunnion to bumper bolt" 118444)
(4) is an aftermarket anti-sway bar (aka "sway bar", ADDCO #127)
The spacer (aka "Tube, distance, trunnion to bumper bolt" 118445) between the bracket and frame extension is not visible at all in my photo. You can see just a bit of one side in Geo's photo, that curved section between the two.
Edited 5 time(s). Last edit at 2018-02-14 10:44 AM by TR3driver.
6TTR3A Frank Conklin
San Diego,CA, USA   USA
This one shows the spacer
FRank
Bracket-2.JPG    31.9 KB
CFMTR3A Avatar
CFMTR3A Carl M
Tampa, FL, USA   USA
Bruce - before you install, could you please post a side view of the bracket including the measurements?
Mine is missing...
Bracket-118444.jpg    16.4 KB
Peter-K Peter K
Central, ME, USA   USA
Add another photo - I grabbed this a few years ago because I had the exact same question as to fit. If this is your car, thanks!
tr3 left front suspension bumper arm bracket mounting.jpg    69.3 KB
brucejon Avatar
1972 Triumph TR6
In reply to # 1513526 by CFMTR3A Bruce - before you install, could you please post a side view of the bracket including the measurements?
Mine is missing...
Happy to, tonight
brucejon Avatar
1972 Triumph TR6
This should help. I was careful of parallax
WP_20180215_15_39_50_Rich.jpg    22 KB
WP_20180215_15_35_47_Rich.jpg    21.2 KB
WP_20180215_15_35_06_Rich.jpg    16.4 KB
WP_20180215_15_32_10_Rich.jpg    20.3 KB
1970 Triumph TR6
