Discolored tires
6TTR3A Frank Conklin
San Diego,CA, USA   USA
I've used various products to clean and "shine" my tires.
Last month I bought a bottle of Meguiar's High Gloss HOT SHINE Tire Spray
Disaster!
My tires are now an ugly shade of brown.
Anyone else had this problem?
The tires are brand new,
so I washed them with household detergent & high pressure water
to remove any factory preservative, then used the Meguiar's product.
I'm not sure what to use to remove the "brown"
Any ideas?
FRank
grubscrew Avatar
grubscrew grub screw
A very common, normal, continuous process.
Read about why and what to do here:
https://www.utires.com/articles/tire-sidewalls-turn-brown-prevent/
Dave
1970 Spitfire Mk3
FDU 78359L
TCF 575L
Signal Red/Red interior
gfe05111952 Avatar
gfe05111952 George Earwaker
Falls Church, VA, USA   USA
Frank, I had good luck with Griot's Rubber Prep (Griot's Garage). I also use their Long Lasting Tire Dressing.
George
1967 Triumph GT6
1967 Triumph Spitfire4 Mk2
1968 Triumph Spitfire Mk3
pawpace mike pace
overland park, KS, USA   USA
Send a email to Meguires and tell them the problem. They are good to respond and will help you with the problem.
Thanks all for the imput. I was hoping for a
magic solution. Looks like it's going to be "elbow grease"
Some guy on Facebook says use "Pledge" furniture polish????
Frank
Pat.L Avatar
New Wilmington, PA, USA   USA
I believe Pledge is basically Silicon. I use "Forever Black" that I purchase from Amazon, it is a pigmented black dye and gives the tire a satin finish and last for the entire summer with out a recoat. I buy three of their products, one for tires, another for tops and a third for bumpers.
In reply to # 1506107 by 6TTR3A Thanks all for the imput. I was hoping for a
Frank
Patrick
1980 TR8 DHC TPVDV8AT209637
TWOA
1967 Triumph Spitfire MkIII
