Brake Reservoir Height
ShortBulge Brian LeBlanc
Falls Church, VA, USA   USA
Any one know how high the reservoir can be?
ie, measure from base
deciding if I need to pull master assembly off to adjust height before filling with fluid
my hood /bonnet is 80 miles away!
CJD john durant
Southlake, TX, USA   USA
Lay a yard stick along the scuttle. The bonnet is only a single thickness of 20 gage steel. If it is a bit under your straight edge you should be good...as far as how high it can be. If you're worried, those lines will easily bend within reason.
Southlake, TX
'55 TR2
Jacad Avatar
Montreal, QC, Canada   CAN
The height is dictated by the pipes running to the clutch and brake cylinders. If you purchased pre-bent pipes with fittings, once installed they should result in a top height for the reservoir that is lower than the hood.
Barry
- looks like cap is 1/4 inch above yad-stick running from scuttle to front apron
- have to pull mstr cylinder box off to bend these old, looks like original, pipes
CJD john durant
So long as the pipes are not old and brittle, you should be able to massage them down with the reservoir attached. I bought a tube bender when I was replacing lines during my restoration, but more than half the time I just gently worked the tubing by hand. You have to decide where you want to increase/decrease the curvature and press in the area to achieve what you need. Just use care not to force to tight of a radius to prevent crimping.
Southlake, TX
'55 TR2
In reply to # 1501718 by ShortBulge - have to pull mstr cylinder box off to bend these old, looks like original, pipes
Few years back, I was digging through a box of brake parts and tried to pick up a pedal box by one of those pipes. With almost no force at all, it snapped in my hand. That, plus what I've seen of how corrosive old glycol brake fluid can become, has convinced me that original brake pipes are not such a good idea; at least on a car you plan to drive on the street.
1965 Triumph Vitesse
