...more Axle Shims
...more Axle Shims
  This topic is about my 1957 Triumph TR3
ShortBulge Brian LeBlanc
...Just measured end float (finally) after putting new inner axle seals
Float: Getting 0.003 on left and 0.002 on right
- pulling/pushing HARD!
- using Shims that were there when i opened up
"original" shims:
Right: 2 @ 0.015 = 0.03
Left: 4 @ 0.008 = 0.032
...does that seem reasonable ???
That would probably be fine, especially if you don't drive the car hard (racing). Most likely it's been that way in the past as well.
Still, my inclination would be to set it by the book. Maybe by changing one of the .015" shims to (3) .006" shims.
must have been use-her error
Pulled it apart
... lubed the splines and re-sorted the shims...0.16 & two 0.008's on each side
- and came out with floats of 0.005-0.006
