TR3 trunnion and seals
Geoff Noel Barbados Geoff Noel
St. George, Barbados   BRB
Hi, I am restoring my TR3 and am currently working on the front trunnions. I have a question for the experienced among you.
I have a new set of trunnions, the outside diameter is 1 5/16” (see pic)
The seal inside diameter is 1 1/8”, is this the correct size seal or does it just stretch to fit?
Thanks, your help is appreciated
Geoffrey
IMG_1684.JPG    30.1 KB
IMG_1687.JPG    33.4 KB
M. Pied Lourd Pied Lourd
ON, Canada   CAN
Stretch to fit.
Tush
Hey Tush,
Thanks for the confirmation, I appreciate it.
Nice channel btw !
Geoff
brucejon Avatar
brucejon Bruce Jones
Santa Cruz, CA, USA   USA
1969 Triumph Spitfire MkIII
1972 Triumph TR6
Really hard to put those suckers on after you install the control arms. <g>
The process that seems to work best for me is to stretch the rubber seals onto the thrust washer first, then smear grease on both sides and slide the washer onto the trunnion pin. When the control arm is installed, the seal will spread onto the trunnion body and control arm.
Then all too often, split and fall off in just a few years.
Hi Randall,
Thanks, I will give that process a shot.
1976 Triumph TR6
