How to disassemble a master cylinder
In reply to # 1492300 by mcoomey Thanks, Barry and Randall. Now I've got more info on brake fluid than I would have guessed existed and I'm sold on the DOT 5 Silicone. It's strange about the brake switch, though. I wonder if anyone is looking into that.
I've looked at it a little bit, on my cars. Not sure exactly how, but it seems that somehow, a tiny amount of silicone is working it's way past the diaphragm inside the switch, and fouling the contacts. I've heard that it doesn't happen with some switches; but all of the ones I have tried (including the original switch on my previous TR3A and a replacement for a Ford truck) have failed. The failure is kind of insidious too; seems like it just keeps taking more and more pressure to operate them.
I finally solved the problem by converting to a mechanical switch. On the 3A, I mounted the switch to the pedal box, ala TR4. That car was strictly daily driver, so I didn't worry about what the engine compartment looked like
With my current TR3, I wanted a more stealthy approach (plus I wanted to keep the original adjustment screws on the pedals), so I made up a bracket to fit a switch under the dash. (Obviously still not a show car, but it might be someday.)
KingstonO Avatar
KingstonO Simon Oliver
Vancouver, BC, Canada   CAN
Michael .. I've used Dot 5 silicone fluid in both my lbc's for many years, with excellent results. The pressure brake light switches are another matter however, (sometimes lasting a few months, and once only one day!), so I followed a tip (Randall's, I think), and installed an updated mechanical switch - Moss part #542-371, listed at $14.99. So far, so very good! It was an easy job, involving: re-routing the two wires from the original switch - through the firewall, behind the heater, and through the firewall again; enlarging the hole in the box just a little to accept the new switch, and then fiddling a little to work out the exact placement. I'm very happy with the result .. and just a little less nervous about being rear-ended drinking smiley
Cheers! Simon.
TR3 brake light switch 001.JPG    43.6 KB
TR3 brake light switch 002.JPG    38.7 KB
Jacad Avatar
Montreal, QC, Canada   CAN
Has anyone tried the SW-32 pressure switch? Supposed to be "silicone compatible" http://www.ronfrancis.com/prodinfo.asp?number=SW-32
ATTENTION: THIS updated version of this trusty switch is D.O.T. compliant which includes silicone fluid compatibility and it is capable of 200 -300% more cycles
Barry
Edited 1 time(s). Last edit at 2017-10-17 03:09 PM by Jacad.
mcoomey Avatar
Paxton, MA, USA   USA
Well, I've already purchased a new pressure switch from Moss, but will be prepared for it to fail. I'm not sure if I'll go with the silicone-compatible or mechanical option though, but thanks for the information and pictures. I'm actually kind of looking forward to its failure so I can try to figure out why!
Michael Coomey
Paxton, MA
'57 TR3
Jacad Avatar
Great Michael,
If you can figure out why they fail you can update everyone who has a 1/8 NPT pressure switch As you can see from these threads below this is not a problem unique to TR's ...plenty have gone before you in trying to understand the problem and possible solutions
https://www.minimania.com/msgThread/109490/1/1/Hydraulic_brake_switch
https://www.jalopyjournal.com/forum/threads/whats-the-negative-of-silicone-dot-5-brake-fluid.185724/
https://www.fordbarn.com/forum/showthread.php?t=160945&showall=1
http://www.sw-em.com/hydraulic%20brake%20light%20switches%20notes.htm https://porsche356registry.org/article/159
Barry
