TR3A Front Bumper Photo Help!!
jerburke Avatar
jerburke Jeremy Burke
La Habra, CA, USA   USA
I'm in the process of assembling all the parts required to get my front bumper mounted.
My car has no front bumper or brackets. So I have nothing to start with.
Could someone please post some pictures of your front bumper and how it gets mounted to the brackets? And perhaps how it gets mounted to the frame?
I'm looking for some visual aids.
Jeremy
1960 Triumph TR3A - Originally purchased new by my Grandfather
1929 Ford Coupe Hot Rod - Family Owned Since 1966
1929 Ford Roadster Pickup Hot Rod - Father/Son Project
2007 Toyota Fj Cruiser - Original Owner
mcoomey Avatar
Paxton, MA, USA   USA
I don't have any pictures, but this exploded view from Moss Motors might help.
Michael Coomey
Paxton, MA
'57 TR3
moss_front_bumper.jpg    48.8 KB
jerburke Avatar
Thanks Michael,
I do have this drawing and will most likely use it when assembling my front bumper. It is very helpful.
I was hoping to see some actual pics.
Especially the bracket to frame mounting.
-Jeremy
jerburke Avatar
Just bumping this topic back to the top.
Still looking for some pictures.
Jeremy
Not the best photos; but maybe this will help. You'll have to ignore the aftermarket sway bar. But you can see the bracket that runs from the back of the apron down to the frame, along with the little reinforcing strap that goes up to one of the steering box mounts.
jerburke Avatar
Thanks Randall!
I'm going to go out and compare your pictures with what I have.
-Jeremy
jerburke Avatar
Randall,
What is the part that I’m pointing to with the green arrow? It looks like the bumper bracket goes between it and the frame.
Jeremy
50169915-48DB-4750-9124-5954DE27D92F.jpeg    53.6 KB
That's right. The bumper bracket goes against the side of the frame, then there is a small spacer to bridge the gap in the center of the bracket. The piece you arrowed is the reinforcing strap that I mentioned before.
Then a long bolt goes through the strap, spacer, bracket and frame, then the radiator guard on the other side of the frame.
jerburke Avatar
Fantastic!
Thank You!!
-Jeremy
CFMTR3A Avatar
CFMTR3A Carl M
Tampa, FL, USA   USA
In reply to # 1494073 by TR3driver That's right. The bumper bracket goes against the side of the frame, then there is a small spacer to bridge the gap in the center of the bracket. The piece you arrowed is the reinforcing strap that I mentioned before.
My project does not have the strap referenced in this post and the related image. I can't find any part numbers listed in SPC. Is it only on the driver's side? Purpose? Needed?
Carl
jerburke Avatar
In reply to # 1495128 by CFMTR3A
Carl
I also do not have this reinforcing strap on the passenger side. It only occurs on my driver's side.
I'm curious to this as well.
-Jeremy
I believe the bracket is to help stiffen the steering attachment to the frame; even though the workshop manual calls it "the stiffening bracket for the bumper". Thus it's only found on the driver's side.
The SPC is a bit confusing, the 3A bracket is listed twice, but the TR3 version only once. Here's the 3A listing from the bumper section (which includes the spacer and extra long bolt).
untitled.JPG    33 KB
untitled1.JPG    17.9 KB
CFMTR3A Avatar
CFMTR3A Carl M
Tampa, FL, USA   USA
I couldn't find the bracket or spacer on either Roadster Factory or Moss. How important is it?
I guess I could manufacture something if I knew dimensions, thickness, Etc.
