After 50 years of ownership....
Lancero Avatar
Lancero Lance Winger
Springfield, OR, USA   USA
Thanks again Joe, UPS did a job on that tranny. Sounds like Macy is a great outfit. Looked at their site, nice! I saw in your bio that you broke a crank also. I picked up a used one for $80 back in 80. We seem to have same approach, make em better and drive em. Mine is better than ever, now that I've got the time and money to make it nice. I'm going to pull my apron and rebuild steering box and have radiator boiled, this fall. Did you see my old pics in my 1st forum entry a week ago under "new member" ? later Lance
Starshark Avatar
Starshark Joe Garcia
Gainesville, GA, USA   USA
1960 Triumph TR3A "White Knight"
I did not see your post...will check it out...yes...snapped the crank in half near the flywheel down shifting hard while on HY 280 in San Jose. I also had the car start on fire...carpet smoked a bit while zooming towards school in Palo Alto on Alma Blvd. Many, many adventures. I too just had the radiator fixed (before and after pics)...and the steering box...I also installed Macy's Hurricane fan...I bet our cars have aged exactly the same way.
Joe
20160219_170527.jpg    49 KB
20160307_131111.jpg    46.1 KB
20160229_085529.jpg    45.4 KB
20160605_140632.jpg    40.9 KB
Lancero Avatar
Joe, Glad to hear you rebuilt your steering box. Mine leaked all it's oil back in the day before I knew why it steered hard. I keep it full now but leaks real good and it's easy to wiggle the arm, so the bearing is bad. So I figure at least bearings and seal will be needed. What all did you change on yours? Was it very hard to remove steering wheel? I've got non-adjustable wheel. I read where Randal rebuilt his box and was very pleased at how much easier it steered. I would enjoy easier steering. I totally rebuilt the front suspension last fall and it turned out good. Parts were really worn out but the darn car actually steered tight, just would act poorly on certain pavements or bumps. That fan looks great. I bought a TR-6 fan from TRF before I read about your experiences with Macy and saw their fan. Not sure if I should eat the $50 I paid for TRF fan, which needs to be mounted backwards to fit, and get Macy's better one. Thanks yet again, Lance
Starshark Avatar
Please check your Idler arm first...I replaced my about 30 years ago...might be the cause of the steering wiggle.
Guess what!? Surprise! The steering shaft outer column is braised to the steering box body and it was very loose on mine...my leak was there...after removing EVERYTHING I tried to solder it back when on the bench...I failed...after my rebuild, I had to wrap the outer column/steering box interface with anti-oil leak tape which seems to work...the nose was back on and I said to myself "perfection is the worst enemy of good enough" The steering box rebuild was a bear...the worm gear was marginal and I left it in place since it would require major shaft welding...I did replace the pressed in steering pin... it took over 8 tons of pressure to pop it out at a local mechanic shop. After I replace both common upper and lower bearings, (using Macy's tech tips), I had to order more shims to put the front cover back on...without the extra shims, it would bind and be too tight...why? I have no clue. BTW...my steering doesn't leak but it still a bear to turn lock to lock when the car is motionless. I had to mess with the pin pressure adjustment several times to get it "OK". In hindsight, I should have set the whole mess to Macy in Ohio. But my self esteem would not be as great as it is today.
20160226_152052.jpg    43.4 KB
20160226_155533.jpg    37 KB
20160226_155552.jpg    42.5 KB
20160226_155607.jpg    28.4 KB
Lancero Avatar
That doesn't sound like a fun time. Maybe I'll look for some help. I put new idler arm in last year during front end rebuild. I can wiggle the arm attached to steering box. I'll check for leak on column. Will let you know how it goes. Good to know what I'm in for, thanks one more time.
Lancero Avatar
Joe, Well I'm deep into steering box rebuild. My column was tight so no leak problems there. I had a qualified friend/British specialist look over my parts and said I could get by with bushing and pin. He said ball bearings looked good and they really don't have much load and no heat on them. That saved me $100. So I had machine shop do the pressing and I'm putting it back together. My friend said I would likely have to remove a shim to take up for wear. Well I reassembled with all of the shims and there wasn't any end play at all. Shaft turned pretty good and I know I don't want end play anyhow but thought I'd have some and would like to know where I stand. I tried making a temp shim out of beer can doubled but still no end play. I sure would like to have ordered extra shims, like a thick one. I see now why you didn't enjoy the job much. What did you use for oil in gear box? Also I took radiator in for a cleaning and they had to rod it out. I was glad to know that my cooling will be much improved. Putting a better fan on, too. Can't wait for the pin pressure adjustment. Shop manual say to drive 1st to adjust as needed. later Lance
Starshark Avatar
Good for you! So where was the leak? ...around the horn/turn signal shaft? I used 40 wt. oil gear oil in my steering box. Good steering is always a good thing! I just polished up my carbs with a polishing kit I purchased for my grinder...worked great! Now's the time to doll up the engine compartment.
Joe
20171105_111640.jpg    44.5 KB
20171105_101456.jpg    35.3 KB
20171105_101451.jpg    44.1 KB
20171105_111538.jpg    39.4 KB
Lancero Avatar
Wow Joe those dash pots look stunning! Nice. My box was leaking around wires and at seal on steering shaft. How did you come up with proper shim pack? Or how much pre load is needed? I assume your old shims weren't enough. I wonder if they set pre load tight at factory. My preload with old shims is tight but things turn fairly easy by hand. Getting any driving in, in Georgia? I've been skiing here. later, thanks Lance
Starshark Avatar
I purchased extra shims from Moss...had to use a bunch more...I can't remember exact number (CRS setting in)...three???...two thin ones and one thicker one??? Anyway, I really needed them...steering box would bind up if not for the additional new shims...I think you are ok with what you got since you did not replace the upper and lower steering box bearings.
Too cold to drive the TR-3A this week...my ears would freeze off...so I have a new winter project in the garage...a 2002 Honda jet ski who's upper deck had several "spider cracks" on the nose and rear of the Personal Water Craft (PWC) due to smashing into docks by teenagers...had to dremal out the spider cracks, yup, each ()&*(&%$ one...then...sand and now for marine filler....then sand a bunch more and then gelcoat and sand with 600 to1500 grit...I am new to this process...thank God for YouTube. I belong to Lake Lanier GA. ROMEO (Retired Old Men Eating Out) PWC jet ski club...we zoom around terrorizing lake restaurants every Friday...then trailer our boats to another lake once a month...once a year we go on a three day river guided tour...last year we did the Cape Fear River. We are down for the winter and will restart our summer schedule next spring. The 2002 Honda was purchased ($1,200 with trailer! Such a deal!) to tinker with...it has a turbo and can hit 65 mph...way to fast for sane people. I plan to replace the turbo when it goes TU...soon since the boat has gone through the gold posts of life and has over 220 hours on it. My 2012 Yamaha is now for my wife.
Keep bending the knees to ski well!
Joe
20171119_140640[1].jpg    38.9 KB
20171119_140702[1].jpg    38.8 KB
20171119_140305[1].jpg    30.4 KB
20171119_140611[1].jpg    39.4 KB
Lancero Avatar
Thanks Joe, I finally got inner bearing collar out and made sure no grit was behind it, so am a bit more confident about putting back as was. I guess as long as it turns without binding it's right. I put a couple .016 feeler gauge pieces in the mix and finally got a tiny bit of end play. I'll probably call it good. Sounds like your a speed demon. Why not. Good to be active and a thrill now and then keeps a guy young. Sure am impressed at your clean garage! Enjoy....Lance
pop5948 Avatar
pop5948 Silver Member Wayne Telman
Townville, SC, USA   USA
So cool to have had the car for 50 years. Neither one of you have changed. LOL I am sure that many of us on the forums have similar photos of ourselves as young guys with our pride and joy.
Starshark Avatar
Yup....we've put on some miles haven't we...The only real issue is that the car is shrinking more every day!
1969 Triumph GT6 MkII
