Just to be sure I got it right
chris Avatar
Pendleton, OR, USA   USA
To install an A type TR6 o/d trans into a TR3A, you use longer trans bolts on the engine, the TR3 flywheel and clutch assembly, TR3 t/o bearing assembly, and maybe oblong the rear trans mount holes. Right? I'm close.
Member Services:
Used English car parts.
M. Pied Lourd Pied Lourd
Ontario, Canada   CAN
I used the TR6 clutch though....
Tush
chris Avatar
What is the difference??
Member Services:
Jacad Avatar
Montreal, QC, Canada   CAN
Chris,
That is my setup, an early CD24870 TR6 Tranny with "A" type O/D, TR3 Clutch, release bearing & Sleeve. Never had to oblong the rear mounts.
Barry
CJD john durant
Southlake, Texas, USA   USA
In reply to # 1475118 by chris What is the difference??
TR3 uses coil springs in the clutch...the 6 uses a diaphram. The tranny front cover/sleeve must match the clutch you pick.
Southlake, TX
'55 TR2
Redding, California, USA   USA
1962 Triumph TR4
1963 Triumph TR4 "MR.T"
The bolt pattern for the clutch on the flywheel is different between the TR3/4 flywheel and the TR4A/6 flywheel.
So you need to match the clutch to the flywheel you are using. Or have the flywheel modified with the different bolt pattern .
Charley
I also had to make longer studs for the 3 studs at the top of the engine block.
In my experience, although you can force it together without slotting the holes, motor mount life will be severely reduced if you do. All of the 4 synchro boxes are about 3/8" longer at the mounting points than the 3 synchro boxes.
And you'll need to do something with the clutch slave, as its mounting surface moves backwards as well. I fabricated a shorter pushrod, but pounding the lip of the cover flat and mounting it TR6 style would probably work too.
chris Avatar
OK! So, longer mounting studs, 3 clutch on 3 flywheel with 3 cover plate and collar on 6 transmission. Cool! And thanks for sharing!
Edited 1 time(s). Last edit at 2017-08-02 09:27 AM by chris.
Member Services:
Jacad Avatar
Chris,
I would take Randalls advice on those minor mods as my own setup came to me that way. The extended motor studs and shortening of the pushrod makes good sense due to the thicker bellhousing of the TR6 Tranny. As stated my rear mount shows no sign of oblonging but it is a tight fit so go with the suggestion.
Barry
IMG_0474.JPG    54.1 KB
IMG_0477.JPG    45 KB
IMG_0481.JPG    63.3 KB
IMG_0482.JPG    53.1 KB
John already mentioned this, but I'll expand a bit. If you do use the TR4A-TR6 diaphragm clutch, you have to be sure your gearbox has the shorter front cover on it. One of those oddities, the factory did not change the part number, but the cover definitely got shorter when they went to the diaphragm clutch. (I'm using the diaphragm because it's lighter and my alloy flywheel is only drilled for the later clutch.)
From what I've heard, the shorter front cover works OK with the earlier spring clutch, but I haven't tried it myself. I used a TR3 front cover when building my Frankenbox; then had to cut it when I went to the later clutch & alloy flywheel. The longer cover will go together with the later clutch, but raise a racket when you depress the clutch. The hole in the center of the diaphragm closes up and grabs the tip of the cover.
chris Avatar
Is it possible to modify the TR6 front cover/sleeve rather than use a TR3 cover/sleeve?
Member Services:
chris Avatar
Ok, but if I use the TR3 clutch on a 3 flywheel, I can use the longer front cover?? And if not, can the TR6 front cover be cut back?
Member Services:
Its the TR6 cover that is shorter. I've heard that the short cover works OK with the TR3 clutch, but haven't tried it myself.
I'm running an early cover that was cut down for use with the later clutch. Works fine for me. Not sure how many miles I've got on it, but has to be getting close to 100,000.
chris Avatar
I would prefer to use some version of the TR6 cover plate so as to not butcher the TR3 trans, hence the question.
Member Services:
chris Avatar
In reply to # 1475233 by Jacad Chris,
So, we're talking about longer studs, but I'm only seeing bolts in the picture, with one missing on the upper driver's side. ??
Member Services:
