Cannot locate bleeder screws on my 57 tr3 front calipers
Diamond Dave David Victor
Albany, GA, USA   USA
I can't locate the bleeder screws on my 57 TR3
Should be very obvious, right next to the cross over pipe on the side without the hose.
But it might be yours have been modified or replaced with something else. Can you post a photo?
TuRtle5 Avatar
TuRtle5 Kevin Kelly
Absecon, NJ, USA   USA
1959 Triumph TR3A "Drandulet"
1968 Triumph TR250    & more
...or perhaps broken off?
TR3barton Avatar
TR3barton John Taylor
Greenfield, MA, USA   USA
Hello,
If they have been broken off bless you my son. Getting them out is often a slow task but almost always possible and involves heat and smoke.
Get that area of the caliper hot not just warm but hot with a torch and melt a candle into the threads. Using an easyout or simply jamming in a minus screwdriver into it
will likely turn it out.
mcoomey Avatar
Paxton, MA, USA   USA
Here's a picture of a broken bleed screw (near my index finger) on the caliper. I wish I had John's advice in removing it before I made my failed attempt! I didn't try heat because I was fearful of cracking the casting. I tried soaking in WD40 and using progressively larger EZ-outs until my drill drifted and I damaged the threads. I ended up bringing it to a professional who saved the day by drilling it out completely, tapped the larger hole, fabricated a custom sleeve to screw in and micro-welded it in place. He saved the day for me but at a cost of $250!
Michael Coomey
Paxton, MA
'57 TR3
broken_bleed_caliper.jpg    35 KB
TR3barton Avatar
Listers,
I do not know why the heat/candle issue lets us extract rusted bit but my humble experience has been
positive.
1968 Triumph Spitfire
