Buy, Sell & Trade Forum
Anyone have any old brake master cylinder parts? [BC, CAN]
GT6 Parts Spitfire Wanted
  This topic is about my 1975 Triumph Spitfire 1500
spitflier Murray M
Vancouver, BC, Canada   CAN
Hi - I'm trying to find the little plastic bit that goes on the end of the secondary piston in a older style tandem brake master cylinder for a 75 Spitfire. Any help would be much appreciated! Mine got launched into oblivion during a clumsy rebuild. Doesn't seem to be something I can get through my usual online parts suppliers.
Thanks!
Murray
Tryumph Avatar
Tryumph Kurt Hollenbeck
Plano, USA   USA
Can you post a photo. I have a Master Cylinder from a 1975 in my storage unit and can take a look. I actually have an entire 1975 Spitfire that I use for parts so if you need something unusual and unobtainable I may have it.
Kurt - Dallas, Texas
Murray, If you are looking for the plastic bit on the end, get the size. Most were the same, but not all cylinders were the same in the back, so measure that metal piece the bell clip goes on, that would be the same size..
Edited 1 time(s). Last edit at 2018-01-03 08:54 AM by trrdster.
spitflier Murray M
The part is labelled #13 (valve spacer) on the attached diagram. My MC bore is 3/4".
4714_001.jpg    48.9 KB
The size of the piece you want is really 15, don't recall ever seeing one 3/4 inch.
Let see if someone close to you pipes in, if not I will get you one, pretty standard stuff, in even the early masters.
Seanolio Avatar
Seanolio Silver Member Sean McKenna
KAMLOOPS, BC, Canada   CAN
I'm in Kamloops and should have it. I'll be at the garage tomorrow.
Cheers Sean McKenna
Totally Spitfire
Seanolio Avatar
Murray... look like what you need?
Cheers Sean McKenna
Totally Spitfire
1515257779162974104917.jpg    23.8 KB
spitflier Murray M
Yeah sure does! I'll PM you!
1968 Triumph TR250
