Buy, Sell & Trade Forum
FS: 1976 Triumph TR6 [Louisiana, USA]
aebreard Armand Breard
Monroe, Louisiana, USA   USA
1976 Triumph TR6, 2.5L six cylinder, 4sp transmission. Rust Free car from Arizona, restored 15 years ago. This car is a 9 out of 10 quality. Hard top included. The interior is also a 9 of 10 with no rips / tears.
NEW:
- Front brake rotors, calipers, pads, rear wheel cylinders and shoes
- exhaust system
- Timing chain
- wiper motor
- dash pad
- wood dash
- front wheel bearings
- upper ball joints
- engine oil and filter
- air cleaner
- top line soft top
Rebuilt:
- rear differential
- steering bushings
- door window rubber wipers and felt
- coolant system flush
- Stromberg carburetors rebuilt and balanced
Extra:
- original ***hard top
- 4sp transmission
- complete set of wheels
- tonneau soft top cover
- tonneau cockpit cover
- extra set of Stromberg carbs
This TR6 is incredible to look at and drive. The body is rust free and straight with only a few small paint chips on edge of engine bay. The rear shocks have the standard shock support kit installed. Tires are only 10% wear. It does not shake or rattle while driving. Steering is tight and aligned, goes down the road straight with no pulling to either side. Brake pressure is strong with no pulling to either side. Transmission is also tight with synchros woking fine. Clutch has normal stiff feel with good pressure and engagement.....does not slip. Has all original Smith gages....electrical system has been groomed and checked.
Good driver and reliable.
Asking for $10200 shipped
dsixnero Avatar
dsixnero Dan Colanero
Westville, New Jersey, USA   USA
Why so cheap? car looks real good. Dan
