Buy, Sell & Trade Forum
1971 Triumph TR6 Supercharged [TN, USA]
Car For Sale TR6 Wanted
jonoverton80 Jon Overton
Knoxville, TN, USA   USA
Listed on consignment for our client in Anderson, SC.
No - it's not a Tesla, but I couldn't select this particular make and model.
This car has undergone a complete nut and bolt restoration over the past two years. The goal during restoration was to create a fast, reliable, excellent handling TR6 that maintained the purpose and aura of the original car. If you are a purist read no further as this car is far from original, if you are someone that appreciates purposeful upgrades to maximize a platform please read on. No expense was spared on this car, it has been well sorted and is ready for the next owner to enjoy.
The restoration began at a shop called Hot Rods 101 located in Upstate, SC. The body was separated from the from the frame and both were media blasted to bare metal. The frame was in excellent shape and checked for symmetry/crash damage and checked out very nicely. The mounting pins for the differential were replaced and reinforced and the frame painted black. The body was also in excellent shape other than a fender that had been body worked, a rusty rear valence, and floors that had seen better days. The aforementioned body parts were all replaced with new metal, gaps aligned (better than factory) and the car was primed/painted using PPG base/clear coat. Final assembly of the car was completed and then sent to Flying Circus Motors in Durham, NC for sorting. Below is the build list for the restoration.
Car is currently located in Anderson, SC. Please feel free to contact with any questions.
Exterior:
-Jaguar Racing Green Paint
-PPG Sapphire Base/Clear Coat on bare metal respray
-Stainless steel bumpers
-New Windshield
-New convertible top with zip out rear window
-All rubber seals replaced
Engine:
-All machine work performed by Clements Race Engines in Spartanburg,SC
-JE forged pistons with an 8.25:1 compression ratio (20 over)
-Block line bored and Cam Shaft bearings installed
-Wishbone Classics Supercharger Camshaft, tappets, valve springs
-Bronzed valve guides
-Moss Motors Supercharger kit with high compression pulley
-Custom cold air intake system with Richard Good air filter relocation kit
-New oil pump
-Case modifications for increased oiling
-All rotating mass balanced
-PRI light weight flywheel
-123Ignition electronic distributor with dyno tuned curve
-Alloy valve cover
-Goodparts 1.55:1 Roller rockers
-ARP head studs/flywheel bolts
-Head oil feed line
-Crank case vent with catch can
-Goodparts PCV Valve with catch tank
-New motor mounts
Exhaust:
-Wishbone Classics stainless header
-Custom stainless exhaust
-Dual mufflers
Transmission/Differential/Axles
-HVDA 5 speed transmission conversion
-Modified driveshaft with new U Joints
-Stainless clutch hydraulic line
-Nissan R200 limited slip differential with 3.69:1 ratio
-Goodparts CV Joint Axles (major improvement)
Fuel System:
-All new 3/8 fuel lines
-Holley electric fuel pump
-Aluminum fuel tank
Cooling:
-Wizard Cooling radiator
-Electric fan (thermostatically controlled with override switch)
-Richard Good polished aluminum radiator shroud
-Custom radiator catch can
Wheels/Tires:
-Minilite replica 15x5 wheels
-New Kumho Tires size on all 4 corners
Electrical:
-Advanced Auto Wire wiring kit
-Inertia cut off switch
-123 Electronic Distributor with custom dyno tuned ignition curve
-Lucas Sport Coil
-Bosch Spark Plug WIres
-NGK Plugs
-Autometer Sport Comp Gauges
-Calibrated fuel sending unit
-Gauges-Speedo/tach/fuel/water temp/vac-boost/voltage/oil pressure/wide band Air:Fuel
-High torque mini starter
-GM alternator Conversion
Interior:
-Victoria British biscuit interior kit
-New wooden dash
-New dash cover
-New under dash cover
-New center console cover
-Mountney Leather steering wheel
-Custom metal transmission tunnel cover to reduce chassis flex
Brakes:
-Rebuilt front calipers
-Stainless steel brake lines
-Brembo front rotors
-New shoes/pads etc
-Rebuilt brake master/booster
-New hard brake lines
-New shoes
Front Suspension:
-All pieces powder coated
-GAZ adjustable shocks
-Moss Blue performance springs
-Goodparts 7/8 sway bar
-New bearings etc
-Nylatron bushings
-Aluminum steering rack mounts
Rear Suspension:
-Goodparts adjustable trailing arm mounts
-Revington TR 5/8" adjustable rear sway bar with spherical bearings
-Revington TR rear shock conversion kit (shock in spring) with adjustable shocks
-Nylatron Bushings
Also included:
-Bentley Manual
-Haynes Manual
-Indoor car cover
Vendors:
goodparts.com
roadster factory
moss motors
Revington TR (UK) revingtontr.com
Wishbone classics
Advanced Auto Wire
123Ignition.com
sparrowpi Avatar
sparrowpi Silver Member David Sherrow
Beautiful car
It has been very well cared for.
Still available.
BigChill Avatar
BigChill Silver Member Big Chill
Norwood, MA, USA   USA
Jon,
Please send me a pm about this. I have some questions and want to talk.
Jim Hurley
Big Chill
lwk47 Larry Kroll
Park Ridge, IL, USA   USA
By any chance is the BRG 1971 Triumph still available ?
Yes it is. Shoot me a text or call me at 865-209-7387
markrl Mark Laura
Middletown, NJ, USA   USA
Hey,
I'm new here. I am looking for TR6. I am a member of the 6 pack and someone forwarded your car to me. This car is just incredible! She's really beautiful. I'm sure its out of my price range! Its a real awesome car. Please let me know what your asking?
Thank you,
Mark
28,000
markrl Mark Laura
Thank you for the response. Its a little more than I am looking to spend but will sure keep it in mind!
Its really something!!
Thank you again!
Mark
MGBritV8 Roland A
New York, NY, USA   USA
Hello,
Interested if still available.
Thank you.
rjc157 Avatar
rjc157 ralph c
pearl river, NY, USA   USA
Except for the color a lot of car for the money probably at least 15g in upgrades
In reply to # 1508333 by MGBritV8 Hello,
Thank you.
It is still available.
trtyme Tom Tyme
Buford, WY, USA   USA
LOL
Whats wrong with the color that ruins this carconfused smiley
In reply to # 1508379 by rjc157 Except for the color a lot of car for the money probably at least 15g in upgrades
1974 Triumph Spitfire 1500
