Buy, Sell & Trade Forum
getting hot [PA, USA]
Spitfire
1951biker Chuck Swartzbaugh
York, PA, USA   USA
my 1977 triumph spitfire is starting to run 10% hotter and at light even hotter wear do i look
Kind of a lot of places to look; I would probably start with when was the last time the cooling system was serviced? It's important to keep an adequate concentration of anti-freeze, and change it on schedule (every 2, 5 or 7 years depending on which AF you use) whether you drive the car or not. The anti-corrosion additives wear out with time, not miles.
Then a good tune-up if it hasn't had one recently, including valve lash and ignition timing; plus verifying that the timing advance mechanism is working. If that still doesn't help, I'd have the radiator rodded out and a new thermostat. Etc, etc.
BTW, this is the "Buy, Sell, Trade" forum. Unless you plan to solve the problem by selling the car, you should probably post in the "Spitfire and GT6" forum instead.
Edited 1 time(s). Last edit at 2017-09-24 03:56 PM by TR3driver.
grubscrew Avatar
grubscrew grub screw
I would look on the Spitfire and GT6 forum!
Dave
1970 Spitfire Mk3
FDU 78359L
TCF 575L
Signal Red/Red interior
1963 Triumph Spitfire 4 MkI
