Buy, Sell & Trade Forum
WANTED Overdrive Drain Plug Tool [Ontario, CAN]
T-time Avatar
T-time Barry O
Milton, ON, Canada   CAN
I need an Overdrive Drain Plug Tool to drain and check the filter on my OD, Moss part 386-336
please let me know if you have one a used one you would like to sell and cost
cheers
Barry
59 TR3A
Barry
59 TR3A
68 Mustang
Just a thought, Barry, are you sure your OD has that style of plug? Although Moss lists it for the earlier cars, I believe your car would have had a smaller hex head instead. IIRC the notches didn't come in until the changes for IRS (ie TR4A with IRS).
The plugs can be interchanged, but only if you change some other parts.
T-time Avatar
T-time Barry O
Hi Randall
I think you are right, i crawled under and took a second look.
I tried a 1 1/4 socket for size and a little sloppy, a 1 1/8 is too small
Barry
59 TR3A
68 Mustang
20170829_201827.jpg    52.3 KB
Again IIRC, I found a 30mm six point socket that fit the flats pretty good; but I ground away the taper at the end to give it more bite. I think the flats are actually a Whitworth/BS size; but I didn't have a BS socket that big and didn't like using an open end wrench.
Unfortunately I don't have a photo of it. So here's a shot of the one I made for the later plug (before Moss offered theirs). The bar in the background is actually my previous attempt, which worked OK but was kind of awkward to use.
The socket was originally the axle nut socket for some big truck, which I found on eBay for around $10. The end not visible takes my 1/2" drive breaker bar, which gives plenty of leverage. And the height of the socket lets the breaker bar clear the frame, rockers, etc. with room left over for my knuckles.
T-time Avatar
T-time Barry O
Thanks Randall,
your information is very useful as always, will try a 30 mm socket
Barry
59 TR3A
68 Mustang
1980 Triumph Spitfire 1500
