Buy, Sell & Trade Forum
Huge 15 year parts Buildup.. Between Tulsa, OK & Jacksonville, FL - CLEARING STOCK [Florida, USA]
Flyboyn2144p Avatar
Flyboyn2144p Nathan Willis
Jacksonville, FL, USA   USA
1971 MG MGB "Hubert"
1978 MG MGB "Blah"
1978 Triumph Spitfire 1500 "Sir Spit Frankenstein -for Now"
Ok Ladies and Gents.
Here is the deal....
THIS IS A BIG ADD PLEASE READ ALL THE WAY THROUGH AND TAKE YOUR TIME>> THIS IS A LIFETIME OF COLLECTING AND PASSION BUILT HERE...
I am not wanting to sell!!! HOWEVER with the new job and time I have available I am finding that I truly don't have the energy for this project that I keep working on.
BUYER PAYS ALL SHIPPING AND ALL PARTS ARE SOLD AS-IS!! I HAVE A COMPLETE PHOTO INVENTORY ON MY Facebook.com page..
ALL PICTURE LINKS>>
https://www.facebook.com/pg/Tulsa-Triumph-Spitfire-TR6-Lounge-1805015003115996/photos/?ref=page_internal
https://www.facebook.com/pg/TRIUMPHNEFL/photos/?ref=page_internal
https://www.facebook.com/MG-Lounge-of-NE-FL-and-SE-GA-1484490191812261/
1978 Spit 1500 with 75K mi ORIGINAL -- She is a running and driving (NO FLOORS!)
1978 MGB 1800 With 62K Body miles and BRAND NEW MOTOR!! --- She is a running and driving (NO FLOORS!)
It is located in JACKSONVILLE, FL
- BUYER RESPONSIBLE FOR PICKUP!!!!
So PLEASE LOOK OVER THE IMAGES I HAVE POSTED VERY WELL BEFORE CONTACTING!!
PLEASE SEE THE COMPLETE LIST AND ALL DETAILS ALL THE WAY THROUGH>> LOOKING TO CLEAR ALL STOCK !!!
ALL PRICES ARE LOWER OR VERY COMPETIAVE WITH THE LOWEST EBAY LISTED PRICES FOR CONDITION AND PART - I DO MY BEST TO KEEP CURRENT IF I MISSED BY WAY OFF FOR SOME REASON PLEASE BRING IT TO MY ATTENTION AND IF WE AGREE ON A PRICE>>> I NOT A JERK.. HOWEVER THIS IS A SAVINGS ACCOUNT IN PARTS FOR ME AND I AM NOT GOING TO GIVE AWAY!!!!!!
I WILL ALSO BUY ANY LEFT OVER PARTS PILES IN ANY CONDITION>
JACKSONVILLE FL COMPLETE LIST!
4 Non- OD Trans - 30K Original Miles Both - EC (3 are 75-80 Spit)(1 is 62-74 4 Speed) $350 Each
Spare Motor - COMPLETE short block 1500 $400
4-5 Spare carbs (2-3 are CD 150 Auto Choke) & (1-2 Manual Choke) $150 ea
2Bbl Down Draft Webber / w Cannon Intake - $450
Complete Front Suspension (A-arms, HWD, Links, Spindles) $800 set
Complete Rear Suspension (A-arms, Links, Spindles, HWD) $800 Set
Complete door set X2 $250 Set
5 Soft top frames (All Retract and extend) $150 ea
New trunk Lid (NO DAMAGE – Red) - $500
4 Luggage racks $75 Ea
2 wiring harnesses $85
both years 1500 Drive shafts $75 Ea
Rear Diff (30K mi car) $400
4 Radiators $35 ea
5 Cooling Fans $45 Ea
3 Hub cap sets $80 for a set
3 air intakes 1500 - $55 ea
accelerator pedal $45
3 Front air dams $125 Ea
air filter housing complete $55
Manual choke cable X2 $35 Ea
4 turn and horn switches $45 Ea
several duplicates of all interior switches bezels etc
Several brake masters $45
Several clutch masters $35
New Alternator $145
New Alternator pulley $7
3 Ashtrays $15
Several starters $75Ea
Chrome strips for 3 cars $125Ea
5-6 Air pump brackets $20Ea
3-4 Battery cables each $5
Battery Drain Tube $5
3 Brake Distro valves $35
Body Shims $4Ea
79' Bumper brackets $35Set
Carbon Canisters $80 Set
Cam Holders $5Ea
Cannon Intake $75
clutch kit $20
Clutch/ Brake Pedal Assembly $150
Clutch Masters 4 $35
Convertible top rear plates $15Ea
Convertible top Frame plastics $45
Steering wheel Plastic covers $45
Coolant overflow $20
Coolant bypass valve $35
Convertible top chrome and corners $12 Set
Crank and cam gears $15 Set
Crankshaft Pulley $35
Several timing covers VB# NLA $75 ea
Several coils $5Ea tested
Crank nuts $30
Dash guards $35
Dash upper vents and unders $75
Distributor 2 complete $150Ea
Heat control Bezels $100Ea
Dip Stick 3 $15Ea
Distributor gears $15 Ea
Dog house $250
Door Handles inside and out 6 sets $300 Set
Door Catches 4 sets $25 ea
Door Mirrors 3 $35ea
2 complete E-Brake assemblies $150Ea
Emergency Brake Cables $45
Emergency Brake bolster $35
Emergency Brake Elbow Rest $15
Power coated Engine hoist tabs $45
Exhaust and Intake Clamp set $35
Factory Jack Assembly $150
front and rear reflectors $45
3 front crank brackets $25ea
Front Turn Sets 4- 5 $45 Ea
Front lower Valance $150
Front trunions $20ea
NEW FRONT SUSPENSION HWD KITS $75 FIRM NEW!
NEW REAR SUSPENSION HWD KITS $75 FIRM NEW
4 Fuel pumps $10 Ea
Fuel Gauge Floats 4 $5ea
Fuel vapor filter $15
Fuel tank cap valve $20
Fuel Cap $45
Glove Boxes - Rough $10
4-5 Hazard switches $75ea
7 COMPLETE GAUGE SETS $280 Ea Set
3 complete head light assemblies $200 Ea assm
2 Spare Headlight surrounds $45Ea
Heat Control Switches 2 $125 Set
Hood Latch 2 sets $50 ea
Hood Safety bar $45 ea
Hood Prop 2 $35 EA
Horn Brackets $35set
Horns set $35
Ignition Ballasts 3 $12ea
Ignition Switch w/ Key $125
6 License plate light sets $45 Set
6 Lighter assemblies $35 Set
5 METAL Map light assembliesVB# 8-008 $45 set
2 Lifter sets $10both
Lucas Ignition Module $45
Mirrors interior 3 VB# 9-246 $45ea
Motor mounts VB# 5-528 $8 Set
Rear Lower brackets Suspension $6 Set
3 oil Crank Slingers VB# 2-051 $5ea
Oil Pressure Switch 3 VB# 2-722 / 2-721 $10Ea
Oil filter relocate NLA $75
Oil Caps 3 VB# 9-1689 $5ea
Oil Pan gasket- VB# 1-624NEW $5
Over riders 4 Sets $5ea one
Over rider front bracket VB# MLA $45ea
4 Wrist Pins $Free
2 Push rod sets VB# 1-958 $10 Set
Radio Antenna Adaptor $25
Radio Antenna Full Length $35
Radio Mount Brackets $35
Radiator Brackets VB# 11-360 & 11-359 $45 Set
Rear brake rebuild kit VB# 7-689 X 2 $25
Rear Tail Body Covers VB# 9-9445 & 9-9446 $125 set
Rear diff oil catcher retainer VB# 5-3009 $8
Rear Diff Oil seal Retainer VB#5-092 $5
Rear main Seal Body and seal Housing VB# NLA - $25
Rear Suspension vertical link VB# 5-599 & 5-600 $120 Each
Rear Overrider/ bumper Brackts VB# NLA - $45 Ea
Rear Axle Shaft Assemblies $300 Each
6 Rocker Arm sets VB# NLA $60 EACH
Speedo cable VB# 6-795 $15
6 Alternator brackets VB# 8-1525 $25
Seat Back Levers $ 20 ea
Seat Belt Set - Working VB# NLA $150 Set
Seat Slider VB# NLA $150
Service Meter Speedometer NLA $250
Sway Arm Brackets and clamps VB#5-358 & 5-3531 $10 set
Shift Handles 3 $4
Shocks Front 3 $25 Set
Upgrade Front Shocks – USED – Blue - $25 Set
Spare tire cardboard VB# 9-8410 $65
Steering Column Clamp 77-80 VB# NLA $30
Sway Bar Links VB# 5-291 & 5-292 $20 Set
Tail Light covers 6 sets $100 each set
New in Plastic - Threshold steps Chrome – VB# NLA $100
Throw out bearing set VB# 4-749 & 4-330 $ 100
Tonnoue Cover Mounts Dash VENT TABS - 2 sets VB# NLA $20 Set
Transmission Torque Strap VB# NLA - $75
Transmission Mount Plate VB# NLA - $75
Transmission Dog house boots 2 sets VB# NLA 1975-80 $40 Ea
Trunk Lid Holder 3 VB#9-744 $40 Ea
Trunk Interior lights VB#0-299 $8
Radius arms 5 SETS VB# 5-574 $80 ea bar
Black trim VB# 9-9438 2 pieces – $100 set
Trip reset cable VB NLA - $25
Trunk body inner brackets LH/RH VB#9-9028 $10ea
1971-80 Spit Trunk Lock and release w/ Latch VB# 9-9440 & 9-9732 - $75
2 complete valve sets VB# 1-560 & 1-558 $20set
Interior vent hose NEW VB# 2-497 $15 set
Window Regulators VB# 10-807 & 10-808 $200 set
Water pump body's 5
1. 78-80 complete with cap, housing flanges and pump – 1 $75
2. 75-78 water pump Bodies $30
Washer bottle VB#10-237 $15.00
Windshield wiper motor and cable VB# 0-404 & 9-6131 $120
Windshield wiper arms 1976-80 VB# 9-6112 $15 Ea
Valance front brackets VB# 11-698 $10
TULSA PARTS LIST: $5,387.95
1. Set of Brown Doors w/ Rods, Glass and Adjusters $250 set
2. Complete Clean Fuel Tank VB#10-292 & 2-910 & 7-188 & 3-8075 $150
3. 1971-73 GT6/Spit BLUE Front License plate Valences and one with bracket VB#11-300 $125ea
4. 1971-80 Spit Front Grills – 2 VB#9-94515 $220 ea
5. Rear Convertible top braces - $15
6. 1971-1973 Convertible top Frame – $150
7. Radiator w/ Baffles and Mounts - $50
8. 1971-80 Spitfire Rear Leaf Spring – New Bushings VB# 5-5507 - $150 plus S/H OVS and Heavy
9. 1962-74 4-Speed Transmission – W/ Throw out Bearing assm – Line, Shift handle Setup - $350
10. Front Engine Mount Plate with New Engine Mounts – NLA - $75
11. Rear Starter and Transmission Mount plate – VB# 00-907 $100
12. 1300 Head - $175
13. GT6 Engine timing cover - $75
14. 1300 Engine Pulley $45
15. 1300 Oil Pan NLA - $75
16. MGB, Austin Healey 3000 Door Seal - $10
17. Radiator – no baffles - $20
18. Horn set – NLA - $30
19. 1971-73 Jaeger - Speedometer 73K W/ Brackets - $75
20. 1971-73 Jaeger – Tachometer - $
21. 1971-73 Jaeger – Fuel Gauge - $
22. 1971-73 Jaeger – Temperature gauge - $
WHOLE GAUGE SET TOGETHER - $ 280
23. Misc Water Temp Gauge with Wire - $45
24. Rear View Mirror - $12
25. 1971-73 Turn Cover - $5
26. Bright Switch - $
27. Left and Right rear Lenses - $ 30
28. Carb Kit
29. Turn Signal Switch NIB $45
30. Misc Triangle Black Carpet - $10 Ea
31. Front lower corner turn light body - $15
32. Front corner lights MISC $ $15 ea
33. Headlight Can $ 5
34. TR6 License Plate Light – and spare for parts $ 150
35. Headlight Chrome ring VB#0-690 $5
36. Radio mount Face $5
37. Distributor Cap $5
38. Thermostat NIB $5
39. Champion plugs 4 NEW
40. 4 speed Shift knob VB NLA - $15
41. Turn Relay
42. Starter Spacer ring - $10
43. Speaker Spacer $5
44. Radio face Bracket Small $5
45. Tail light bulb holders – Sockets VB# 0-515 & 0-516 $5 ea
46. Misc Bulbs
47. Ashtray Bracket $5.00
48. Bulb Holders
49. SOLD ITEM
50. Rear brake cylinders $10 ea
51. Steering column bushing
52. Relays
53. 1962-80 GT6/Spit Complete ash tray assm VB# 0-365 $15
54. Transmission mounts VB# 5-522 $5ea
55. Exhaust flange and gasket VB# 1-708 $3.00
56. Fuel cap – ehhh chrome – needs polished VB# 9-2168 $45
57. Valve Cover 1300 VB NLA – Unpainted - $75
58. 1962-80 Spit Rear Brake drums – one small crack at lug hole – VB# 6-673 $20 Set
59. Water Pump Body VB# 2-157 & 2-496 & 12-831 & 12-5054 $150
60. 1971-80 GT6/78 Lower Plastic over riders VB# 9-9406 & 9-9407 $50
61. SOLD ITEM
62. 1971-80 Spit Trunk Lock and release VB# 9-9440 & 9-9732 - $75
63. 1971-72 Spit Intake manifold VB NLA - $45
64. 1971-76 GT6/Spit - 4 door latch external handles VB# 12-486/ 12-485 - $150 ea
65. 1971-80 GT6/Spit - 2 Interior Door latch handles VB# 9-282/ 2-281 $50 ea
66. 1962-80 - 2 sets of hood latch handles good chrome VB# 9-9427 $50 ea
67. 1971-80 GT6/Spit - 3 door retaining latches to strikers VB# 12-496 $25 ea
68. Windshield wiper rods and body $75
69. Engine lift bracket front of head - $35
70. 1300 cam shaft VB # 1-8306 $100
71. 1300 rocker arm set $ 45 Complete
72. 1300 Distributor drive gear VB# 2-067 - $15 Complete
73. 1300 Dip stick - $15
74. SOLD ITEM
75. Starter – UNTESTED – Loose bat terminal – MIGHT KEEP
76. Radio AM/FM British Leyland – untested - $45
77. Radio AM ONLY British Leyland – UNTESTED - $75
78. SOLD iTEM
79. Intake gasket NIP – VB# 1-703 $6.95
80. Wheel Beauty rings - $100 set
81. Black Hubcaps - $15ea
82. 71-73 Ignition Switch Cover - $25
83. Lug nuts bag w/ washers - $35
84. 1962 – 78 Coolant Bottle holder – NLA - $25
85. Wiper Motor – UNTESTED - $15
86. Misc Pulley NIP -$25
87. Convert and door corners - $20 set
88. Rear body Chrome corners - $45 Set
89. Trunk Lid Hinges – SET - $45
90. Overflow Bottle - $15
91. Wiper Motor UNTESTED – MIA Bottom Cover - $15
92. NEW Motor Mount Set- 1962-74 $8 ea
93. Hood Brace for sides and crash control - $15
94. Steering Column Braces - $15 ea
95. License Plate Light 71-74 Spit - $20
This is just from my Photo index. There is more that I have not Photographed.
I am Trying to get bills paid and a move paid for..
ASKING $ CASH...
WILL NOT TAKE A CHECK OR MONEY ORDER!! I WILL NOT SHIP THIS OVER SEAS!!!
I WILL TRADE THIS WHOLE LOT ONLY FOR:
1. A EXCELLENT CONDITION HARLEY CRUISER, - (NO 883's) 1200cc- 1800 + ROAD HAUL READY!! 500mi plus a day! (PLUS CASH)
2. AN EXCELENT CONDITION LOADED JEEP WRANGLER/ TJ/ YJ(ETC) V6 ONLY!! LOW MILES - UNDER 40K mi (PLUS CASH)
3. EXCELLENT CONDITION EQUAL VALUE CREW CAB PICKUP V6 4X4 LOW MILES!!!! (PLUS CASH)
4. Ownership of a Cessna 150/ 172 OR CLOSE TYPE etc.. Prefer to have current Annual and NOT CLOSE TO MOH!!!
5. CASH!!! - and TRADE DEPENDING ON VALUE!!
INBOX ME IF SERIOUS!!!! PLEASE DONT WASTE BOTH OF OUR TIME>>>>>>
20160725_162424.jpg    45.8 KB
Flyboyn2144p Avatar
1978 MG MGB "Blah"
BUMP>>
ALL INVENTORY IS GETTING LOADED IN PICS ON EACH PAGE>>
KEEP CHECKING BACK
Flyboyn2144p Avatar
1978 MG MGB "Blah"
Bump..
Working on both listings within Facebook so there are pics and breakdowns of each. Im only to the "G's" in my titles so far on the JAX page.. Its taken 4 days so far to get to that point. Prob another 8k parts to go.
Please send friends requests and inbox me if your intrested between the 1300 and 1500 stuff.
Again please read the whole add im open to trade for everything.
Thanks and God bless
Flyboyn2144p Avatar
1978 MG MGB "Blah"
bump bump
OUT OF WORK>> NEED TO SELL TULSA STUFF ASAP!!! - BILL MONEY NEEDED
Flyboyn2144p Avatar
1978 MG MGB "Blah"
bump///
OUT OF WORK
Flyboyn2144p Avatar
1978 MG MGB "Blah"
bump
Lou6t4gto Lou Breslow
Ocala, FL, USA   USA
I am in need of a Straight, rust free hood and deck lid for a 1973 TR6. I live in Ocala fla. if you have, please reply. thank you. Lou6t4gto Lou
1971 Triumph GT6 MkIII
