Buy, Sell & Trade Forum
R160 Diff conversion kit, Spitfire GT6 [VIC, AUS]
dherr2 Avatar
dherr2 David Herr
Adamstown, MD, USA   USA
Yes, this works with either the Datsun or Subaru R160 differential.
73Spit Avatar
73Spit Silver Member Kevin Nadeau
Littleton, CO, USA   USA
1973 Triumph 1500 "Toy Spit"
1973 Triumph Spitfire 1500
I am interested in all 3 pieces of this kit for my 73 Spitfire with 4AGE motor in it.
Sparrow010 Avatar
Sparrow010 Andrew Gaskin
Feilding, Feilding, New Zealand   NZL
1971 Triumph Spitfire MkIV "Spitie"
1974 Triumph Stag "Staggy"
Hi Kev
Im in the middle of doing this exact same repower to my spitfire hence needing a stronger diff.
did u use a T50 gear box?
Plan to get production run of diff kit started by the end of this month.
Will sort costing this week once businesses open for the new year
Hav found another place that will do machining of the raw cast diff backing plate rather than use the problematic company in Christchurch.
If there is any one else interested in buying a kit please let me know by the 14th Jan as ill be placing the order shortly after then.
cheers
Andy G
NZ
73Spit Avatar
Yes I used the T50 tranny from the car I got the engine from. 85 Corolla GTS. Thanks Andrew for the help on this thing, can't wait to get her going.
Dlwoolsey Duane Woolsey
Salt lake, UT, USA   USA
I am interested in a kit. Once you get the pricing worked out let me know. Thanks.
Melmac Jerry S
Löddeköpinge, Skane, Sweden   SWE
Please keep me updated too about the kit. Thanks.
1963 Triumph TR4
