DHC Missing Convertible Top Seal
M1kem3 Avatar
M1kem3 Michael Rawlins
San Antonio, TX, USA   USA
I am missing the seal that goes on the windshield frame, sealing the connection between the convertible top and the windshield. What is the proper name of that part, and is this it? https://rimmerbros.com/Item--i-ZKC3099
Edited 1 time(s). Last edit at 2018-02-04 08:50 PM by M1kem3.
POW Peter Wirth
That's it ! Note that it's held in place with left and right retainers. P/N's YKC3342 & YKC3341. You've got those?
sliproc Avatar
sliproc Kevin Quistberg E
Long Beach, CA, USA   USA
Michael,
I'm not positive on this, but I think that part replaces the seal on the header rail of the top frame and not the one on the windshield frame.
POW Peter Wirth
In reply to # 1511580 by sliproc Michael,
True, that part (ZKC 3099) actually is secured to the header rail, but it is the only seal between the top and windshield. There is a rubberized trim piece clipped to the windshield frame P/N ZKC 1432. It is not a weather seal though.
Edited 1 time(s). Last edit at 2018-02-05 11:30 AM by POW.
M1kem3 Avatar
If you’re talking about the things the top latches into, then yes, I have those. I’m pretty sure there’s a seal on the windshield frame, as I don’t think the top is supposed to have one.
In reply to # 1511563 by POW That's it ! Note that it's held in place with left and right retainers. P/N's YKC3342 & YKC3341. You've got those?
POW Peter Wirth
This picture is from Rimmer's catalogue. Of the three long items at the bottom of the illustration YKC3610 and ZKC1432 are the only pieces that are on the windshield frame. WKC3937 is a piece of vinyl cloth that is actually cut and glued to the soft top's header. There is no seal on the windshield frame. ZKC1432 is a rubbberized 'U' shaped flexible strip that merely finishes off windshield frame so it looks good from inside the car. It may be what you are missing, but it's not a seal. https://rimmerbros.com/Item--i-YKC3610
This picture shows the only weather seal for the top ZKC3099 and it is secured to the top header, not the windshield frame. https://rimmerbros.com/Item--i-GRID006143
M1kem3 Avatar
I found a picture of the piece before the car went for paint. What is the rubber part under the top latches?
In reply to # 1511667 by POW This picture is from Rimmer's catalogue. Of the three long items at the bottom of the illustration YKC3610 and ZKC1432 are the only pieces that are on the windshield frame. WKC3937 is a piece of vinyl cloth that is actually cut and glued to the soft top's header. There is no seal on the windshield frame. ZKC1432 is a rubbberized 'U' shaped flexible strip that merely finishes off windshield frame so it looks good from inside the car. It may be what you are missing, but it's not a seal. https://rimmerbros.com/Item--i-YKC3610
03223C6A-A2CC-4CBA-9FBE-A0842E74852B.jpeg    35.6 KB
POW Peter Wirth
Now we're on the same page. This is P/N ZKC1432PA.
https://rimmerbros.com/Item--i-ZKC1432PA
M1kem3 Avatar
Thanks!
In reply to # 1511902 by POW Now we're on the same page. This is P/N ZKC1432PA.
1965 Triumph TR4A
