82 TR7, rebuilt engine run in stopped after 20 min, won’t restart.
nick Avatar
nick nick m
Bend, OR, USA   USA
Here is the setup I removed from 79 car. Alison electronic ignition with the distributor. There are options on this type of setup.
nick
20160226_130314.jpg    33.5 KB
dmtrmp6 Daryl M
FADDEN, ACT, Australia   AUS
Tim, et al,
Check out the following post elsewhere on this forum:- http://www.triumphexp.com/phorum/read.php?3,1287410
Includes a wealth of information and embedded reference material - pictures, drawings, extract from the repair manual, research paper (Tony Rhodes), specs, part number cross references for the electronic module and alternate coil ("coil/transformer thing"winking smiley. Essentially when you break the ignition assembly down into it's component parts the options expand.
Good luck. Rgds, DM
In reply to # 1506722 by nick Here is the setup I removed from 79 car. Alison electronic ignition with the distributor. There are options on this type of setup.
Back when I had my TR7 (1977 to 1980, IIRC) Went through three Opus modules and gave up, converting to the Allison ignition setup you show. No issues after that, so I was happy.
Draegon Tim Barrick
Hamilton, ON, Canada   CAN
Thanks for all the help guys.
I had the new module installed, it still doesn’t work.
It’s the coil, it’s drawing 280k ohms, so is shot.
Does anyone know of the specific coil that I can install in this unit?
It has 4 small bolts that mounts the hei coil into the assembly.
A 1979 Chevy pick-up truck coil is exact in dimensions, but is missing 2 bolt holes, and has a different wiring connector, close but no cigar.
Any ideas?
In reply to # 1506971 by Draegon Thanks for all the help guys.
Any ideas?
Delco D525 (NAPA MPE IC22SB ) is the replacement for the original coil. It is not an exact replacement, and supposedly requires new wires from the module to the coil. I do not know if it has all the mounting holes you are looking for. Full disclosure: I do not have this setup, and have not verified the suitability of the replacement.
Edited 1 time(s). Last edit at 2018-01-11 06:31 PM by Darth V8R.
Draegon Tim Barrick
Thanks Vance, I was just at Napa today, will go pick up that coil tomorrow if I can.
Hopefully it’s not too difficult to wire in.
In reply to # 1507035 by Draegon Thanks Vance, I was just at Napa today, will go pick up that coil tomorrow if I can.
Keep your old coil. You might find it easiest to simply swap the wires and/or the connector between the two coils.
Please report back on any issues, fitment, etc. and of course whether or not it gets your wedge running.
Draegon Tim Barrick
I picked up the coil today.
I went for the premium version, as the one you named was not available. It’s larger than the one it’s replacing, but luckily the mounting for the coil has 4 extra wider spaced holes that the new one will bolt into.
I’ll let you know once it’s rewired.
Just after I got home from the parts store, I got a call from one of my British car places, and the found me the exact coil/igniter that was installed on my TR7. It’s used, but they told me they’ve never seen one fail before...lol
I’ll get it as a back-up in case the Frankensteined unit I’m making fails.
In reply to # 1507165 by Draegon I picked up the coil today.
Here's a NOS one on eBay for $29. Depends on how you feel about eBay, my experience has been mostly positive. So if the heavy duty one does not work out...confused smiley
BTW, the replacement coil does have 4 holes in the bracket. drinking smiley
Cheers,
Edited 2 time(s). Last edit at 2018-01-15 10:07 AM by Darth V8R.
s-l1600.jpg    56.9 KB
1959 Triumph TR3A
