Distributor wrench for TR8
NJ, USA   USA
My wrench for my GM HEI doesn't fit. I used a crow foot 9/16" but it was a pain in the butt......... what are you guys using?
darrellwalker Darrell Walker
Vancouver, WA, USA   USA
1966 Triumph TR4A "Christy"
1981 Triumph TR8 "Kate"
I replaced the bolt with a socket head cap screw, and then use a ball-tip Allen wrench. But if you have A/C, I'm not sure there is really any easy option!
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
NJ, USA   USA
I do have AC. I might bend the offset wrench......
Pat.L Avatar
New Wilmington, PA, USA   USA
With A/C I used a ratchet and socket with a wobble end extension. It will just grab. Can't remember for sure but I think a 12 point worked better than a six point socket.
In reply to # 1504213 by RossL My wrench for my GM HEI doesn't fit. I used a crow foot 9/16" but it was a pain in the butt......... what are you guys using?
Patrick
1980 TR8 DHC TPVDV8AT209637
TWOA
bowen6951 Avatar
Fontana, CA, USA   USA
Ditto for what Darrell said. It works very well and I have A/C. Thanks, Rob
NJ, USA   USA
This is what I ended up with. Used an offset wrench from Harbor Freight. Heated it with MAP gas and bent it in a vise. I had to grind some material away under the first bend at the 9/16's end that contacts the bolt for clearance on top of the timing cover. Using a small LED flashlight also helped to see/find the bolt under the distributor........ I think finding/see the hold down bolt was half the problem
Edited 3 time(s). Last edit at 2017-12-29 11:37 AM by RossL.
Diz Wrench.jpg    39.4 KB
Wrench on diz.jpg    21.7 KB
1964 Triumph TR4
