TR8 power steering
Growling-Grinnall-V8 Avatar
Growling-Grinnall-V8 Alastair Campbell
Portadown, Northern Ireland, UK   GBR
Did all TR8s come with power steering as standard?
The PAS in my converted 7 is a modified SD1 rack.
The TR8 was never available in the UK, so RHD TR8 power racks simply dont exist.
robtr8 Rob Stephenson
Lake St Louis, Missouri, USA   USA
That's OK, they're all crap anyway.
It's a jag rack and I can attest they all leak. At least all of mine did.
This time around I converted to the manual rack and added EPS.
http://leonbirchall.co.uk/easysteer/index.html
TeeR8 Avatar
In reply to # 1501368 by robtr8 That's OK, they're all crap anyway.
Rob,
My TR8 was retrofitted with a manual TR7 steering rack.
Please tell us more about the power steering kit you installed:
1 - Is it a straight forward install?
2 - Installed under the dash at the firewall?
3 - All parts and bits included or did you have to source additional bits?
4 - Any machining or mods required to the steering shaft?
5 - How much time to install?
6 - Is this system adjustable for steering boost level?
7 - Which kit did you order from the supplier - I could not see much detail on the website.
Any additional information would be appreciated.
Henri
1980 TR8, Platinum
1971 MGB GT, Midnight Blue
TR8todd Avatar
TR8todd Todd Kishbach
Mass, USA   USA
1979 Triumph TR7
1980 Triumph TR8    & more
Yes, all TR8s came with the power steering rack. They are the same manufacturer and use the same rebuild kits as the Jags of the era. Personally I'm not a fan, thats why there are several in them stashed in my basement. The car I'm building now is getting huge tires and I suspect the manual rack is going to be too difficult to manage. If that turns out to be the case, I will install an EPS. Tons of write ups on the web on people converting using junk yard components.
He obtains a steering shaft and grafts on the Saturn EPS along with some wiring and a controller.
Once you get it in the mail, you ship him back the core.
Fairly straightforward install although it's a tight fit and I needed to remove one dash support (which he does warn about) and I wasn't able to reconnect the speedo cable (which is also OK because that cable always goes "wichy wichy wichy" and I always disconnect it anyway.)
Effort is adjustable.
I did wind up calling his shop a couple times. He always answered the phone. That right there is worth supporting.
Initially, the EPS fought me. Turns out I got a RHD EPS so I needed to swap the power leads.
Ahhh!
So they used a Jag rack! Always wondered.
Mine started as a 7 and converted to V8 in late 80s by Mark Grinnall, in part using left over 8 parts and some clever butchery.
Used a shortend SD1 rack, so naturally has started leaking at 60,000 miles/30 years since rebuilding to fit TR7. SD1 rebuild kit to sort it.
You'd have thought a RHD Jag rack would have been used. Maybe the Jag rack and SD1 racks re the same beast? The TR8 lower column I got from Rimmers is a perfect fit, both in length and splines.
Good thing about mine is that its a quick rack from the injected 190BHP Vitesse model- 2.5 turns lock to lock. Bad thing is the vague, dead section in the middle.
You can name your own price for a genuine RHD TR8 power rack. Only 60 odd pre-production UK model TR8s escaped the factory, usually bought by employees.
The plan was to launch the TR8 in the UK in May 1982, but clearly that never happened. A cottage industry offering to convert your sprung up shortly afterwards. Most conversions use the manual rack.
Beaverton, Oregon, USA   USA
In reply to # 1501601 by Growling-Grinnall-V8
Alastair:
Shortened SD1 rack? Was the rack housing shortened, or were the tie rods shortened, neither, or both?
It seems to me if an SD1 rack can be fitted, the lack of available TR8 PS racks is a non issue, or so it would seem.
Same holds true if a Jag rack can be fitted.
I was always given to understand that the rack was a bespoke design, made just for the TR8. True?
I suspect the rack housing itself was shortend. I'd need to compare the dims of mine to an SD1 rack to confirm.
The bolt holes for mounting the modded SD1 rack in my subframe are not in the same place as those on genuine 8 subframes.
I'll try and get some pics.
TR8todd Avatar
Mass, USA   USA
1979 Triumph TR7
Dug thru the pile of power racks in the basement because I knew there was an SD1 rack at the bottom still mounted on a SD1 subframe. Took some pics and some measurements. Its obvious these are not the same racks. About the only dimension that lines up ids the inner tie rods are very close in length. Housings are 18" wide for TR8 and 22.25" for the SD1. Mounting holes are 14.5" for TR8 and the SD1 is narrower at 11.25". Inner tie rods are similar at about 11.5". So based on this, I'd guess the SD1 has a track width of about 5 more inches than the TR8 and most of that is in the body of the rack. I'm sure there is more in the offset of the wheels and hubs as well. The control box on top of the SD1 rack points the hose outlets forward. The TR8 control box points towards the center of the car. Hoses and hard lines are completely different. If one was to try and swap racks, The SD1 rack would not be any first choice. I'd love to see what the measurements of a Jag rack are. Might make more sense to tear one of those apart and cut it down to size.
DSCI1799.JPG    71.1 KB
DSCI1798.JPG    52.8 KB
DSCI1797.JPG    58.5 KB
roverend Kent Kinard
San Antonio, Texas, USA   USA
There were at least four different racks fitted to LHD SD1's- Cam Gears (similar to Volvo), Alford&Adler (early and late), Burman, and possibly AdWest.
1966 Triumph Spitfire MkII
