TR 8 Cooling Fan Problem
POW Peter Wirth
That's good info. i wonder what the original twins draw at start-up. I've had no problems with mine as yet but I kind of wonder what the draw is even when up to speed. My 900 RPM idle drops 200 RPM when the fans start and run. What power hogs! Is your AC operational? Since I never used mine here in NH I could not justify hauling around an extra 40 lbs or so for the sake originality. At any rate getting rid of the condenser sitting there right in front of the radiator allowed the engine to run markedly cooler overall which translated to longer times at idle in traffic before the fans come on. I also am using a 180° thermostat.
Beaverton, Oregon, USA   USA
Tom:
I suppose a slo-blow fuse might be an alternative to a 30 amp fuse. confused smiley
bowen6951 Avatar
Fontana, California, USA   USA
Hi Peter,
I also talked to Gerry (Gary?), like Tom said the Mardyne 14" is willing to take as much amperage as you have (G. said it would take 80 amps if you let it). He also told me that the fan box says it needs a dedicated 30amp circuit and I was blowing 15 & 25 amp fuses too. I wound up running #12 wire from the back of the alternator to the relay so it has enough power, and switching it from the high temp sensor on the manifold (EFI) works great. Thanks, Rob
